Question about HP Computers & Internet
Interchangeable HP laptop fans
Would a laptop cooling fan from a HP-2000-2b44dx work in a HP Pavilion G4?
mailtoravi
  • 186 Answers
SOURCE: how to have access to the processor fan for hp pavilion dv5000
I found the Service Manual of the Notebook which contains the procedure about how to remove each and every component of your Notebook and below is the link to access the same :
http://h10032.www1.hp.com/ctg/Manual/c00700932.pdf
Best way is to copy the entire link and paste it in the address bar of a new web browser and press enter to open the link.
Hope this is helpful...
Posted on Oct 06, 2008
benwabnick
  • 2404 Answers
SOURCE: I have a HP Pavilion dv6000 and the fan has started making noises
Its possible but it would require taking out all the screws from the bottom of the latop, taking out the keyboard and the screws from the top cover. Then disconnecting the ribbon for the mouse pad and any other plugs coming from the top cover. After you take off the top cover you'll expose where the fan is at and at that point you can clean it off. If it still makes weird sounds then the fan would need to be replaced.
Posted on Jun 08, 2009
  • 3 Answers
SOURCE: HP Pavilion DV6500 - The fan makes too much noise!
HP deliberately design their laptops to breakdown just after the warranty ... my HP-authorized repair shop told me that there is no way to clean everywhere inside the unit, without complex, nearly complete dismantling.
But I bought another Pavilion!  But I learnt by smashing apart my first Pavvy.  There is only one cooling fan.
Remove the battery.  Put a narrow plastic stick thru the intake slot, to stop the fan spinning.  Then use a hair dryer, without heat, to push air into every air hole you can find.  Repeat with a low-power vacuum cleaner.
After 4 years, sell it, smash it or get rid of it.
Greg Zeng, Australian Capital Territory.
Posted on Sep 04, 2009
athulnair
  • 101 Answers
SOURCE: My HP pavilion dv5 1125nr overheats, looks like
Check the fan speed. It the speed of the fan is low it will overheat..
Posted on Apr 10, 2010
SOURCE: Loud fan noise from hp laptop pavilion dv4.
Try to modify your power plan, i modified the value of process power management and fan noise came down havily. This can be found under advance setting in Power plan.
Posted on May 11, 2010
How to fix a hp m7750n cooling fan
Checking the Fan Turn on your Pavilion and close the display panel.Flip your laptop upside-down and place it on a clean, flat surface. Shine a flashlight into the vent on the bottom of the computer and look to see if the cooling fan is spinning.
http://smallbusiness.chron.com/check-cooling-fan-hp-pavilion-laptop-55670.html
Dec 29, 2016 | HP Computers & Internet
Laptop fan has a noisy and pc is shutdown after some time ..so can I replace the fan ? pavilion dv3-2175ee
How to Replace a HP Pavilion dv3 Fan?
1. Follow your laptop owner's manual and assembly guide carefully you can download this from HP web site as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, CD/DVD drive and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the HP Pavilion dv3 Fan Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and fan. Replace the screws, plug the HP Pavilion dv3 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new fan running and feel warm air blowing from the vent on the side of the laptop. A HP Pavilion dv3 Fan does not run continuously, so don't be concerned if the HP Pavilion dv3 Fan shuts off periodically.
Jan 10, 2011 | Computers & Internet
Hp pavilion 6530ep with fan always working...!!!
This could be a sign that your laptop is overheating. If you touch the laptop while it is running & you find it too hot, make sure that the fan is running properly & that the air ways are not blocked.
You can blow compressed air into the cooling vents of the fan. If you notice clouds of dust coming out, then it might be a good idea to disassemble the laptop, clean the fan & air ways, & reassemble it back.
Oct 14, 2010 | HP Pavilion dv6000z Notebook
My cooling fan has stopped working - laptop is a hp pavilion, model tx2000
If you unplug the fan, you can test the connector to make sure the fan is bad and the problem isn't with the power getting to the fan.
You can get a new fan and heat sink assembly here (make sure the model number is the same as your computer):
http://www.sparepartswarehouse.com/HP,Pavilion,tx2000,KX531AV,Laptop,Fans.aspx
But in the meantime, you shouldn't run the computer much because it can easily overheat without the fan.
Jun 06, 2010 | HP Pavilion TX2000Z Notebook
HP DV2910us -where to order cpu cooling fan for
Best place to look is ebay. Look it up as a DV2000, as far as I know all the dv2000 series use the same cpu cooling fan. Otherwise, if you have the laptop apart, use the serial number or m/n on the part to look it up on ebay. I do this daily at my computer repair store and have lots of luck with hp laptop fans.
Apr 30, 2010 | HP Pavilion DV2910US Laptop
My hp pavilion dv1000 fan turns on for a little bit then turns back off.Do I need to replace the fan?
Are you having any problems with the laptop overheating or shutting down unexpectedly?
Generally the fan should only run as much as it needs to in order to maintain an optimal temperature. the fan will be turning off as the laptop will be cool enough. if however, the laptop is very hot to touch you may have a faulty sensor telling the fan the laptop is cool when it isnt. this generally leads to the laptop crashing or shutting down though if thats not happening i recommend contacting HP for guidance.
it is most lekely functioning properly if you arent having any other adverse effects
Thanks
Dec 21, 2009 | HP Pavilion dv1311se PC Notebook
How to install hp pavilion dv1000 laptop cooling system
Here's a direct link to the service manual for this laptop model:
http://h10032.www1.hp.com/ctg/Manual/c00636251.pdf
On page 168 of this PDF file, section "5.18 Heat Sink" explains how to install/uninstall the heat sink.
On page 170, section "5.19 Fan" explains how to install/uninstall the fan.
Nov 28, 2009 | HP (344872-001) Laptop Cooler, Cooling Fan
I bought HP Pavilion dv5 6 months ago and fan not working
Your cooling fan sounds to have went out,causing it to overheat and shut down.It also could be something in the fan stopping it from turning.Try cleaning it or blowing it out with it off.But it mostly sounds to have went out.
Aug 05, 2009 | Computers & Internet
Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
My HP pavilion dv5 1125nr overheats alot and i dont know if it is a problem with the fan or just the computer... PLEASE HELP!!!
It could be both. Make sure your vents are all free of any dust. Check that your fan is operating properly. If the vents are free and fan is working you have a few choices.1. You could upgrade the fan/heatsink to one that cools more efficiently, or 2. You could spend the $20-30 that a laptop cooling pad would cost and use it under the laptop whenever it's in use. Hope this helps.
Jul 08, 2009 | HP Pavilion dv5-1125nr Notebook
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
