Question about Ovens
My beko dvc565 cooker digital lights have gone off and the oven will not switch on
2 Suggested Answers
SOURCE: Beko Cooker dvc565
once you take of the back of the oven there are some wires going from the cooker to the back cover on one of the wires you will see a microtemp thermal fuse protector this connects the two wires (the white wire) this needs replacing you can get them from tdspares.co.uk we will be getting 121c degree. Hopes this helps
Posted on Mar 04, 2008
MY BEKO DV5531 COOKER WORKS BUT WHEN I PUT OVEN ON FAN LIGHT COMES ON BUT OVEN JJUST BUZZES WHY ??
The blower motor has gone bad and will either need lubed
or replaced.
Sep 01, 2014 | Ovens
Beko fan oven making noise
If you have a problem with your cooker or oven then this diagnostic video will help you find the fault on your beko oven and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jan 08, 2014 | Belling XOU492 Electric Double Oven
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
No fan or heat
Hello..... have you (a) checked that you have power going to the oven...(b)...With the power to the oven switched off open the terminal block (where the cable from your socket enters the oven) check that all connections are secure....(c) remove the rear panel of the oven and check that the safety stat is ok.......(usually small square white or gray unit wit two wires running to it found on rear of main oven...it is usually fixed to a bracket or directly fixed to the cabinet...test for continuity with a multimeter if open circuit ..that is no meter reading relpace it
regards Sir Galahad
Jun 28, 2009 | Belling XOU492 Electric Double Oven
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
Beko Cooker dvc565
Feb 10, 2008 | Ovens
Ovens Logo
29 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
