Question about Hannspree HC-194D 19" LCD Monitor
Open the case hannspree monitor - Hannspree HC-194D 19" LCD Monitor
How do I reset to Factory Settings?
Hello Julie,
Do you own a Hannspree touch screen monitor or normal computer monitor? Either way, click below and you will find directions on how to accomplish this.
Good luck! http://www.hannspree.eu/en/faq-tvs-monitors
http://www.hannspree.eu/en/faq-touch-monitor
Mar 24, 2015 | Hannspree HANNS Computers & Internet
My hannspree has a yellow light on and the screen does not turn on
I would first suspect a power supply issue in the monitor, it would require at the least opening the set and looking in the power supply for signs of damage, if its a year or two old look carefully for puffed up caps.
If you are not able to safely get it apart have a tech look at it for you.
In case you do get it open here is what bad filter caps look like, if find that they are fairly easy and inexpensive to replace.
Dec 20, 2012 | Hannspree 28 Hf289h Hdmi Blu ray 1080p...
Hi, I have a Hannspree 19"
The inverter board is most likely the problem, often caused by bad capacitors that sometimes puff at the top, indicating it is open. The inverter can be repaired, or the board must be replaced so long as the monitor is not to old each manufacture is different in their policy making.
Mar 13, 2011 | Hannspree 19" Widescreen LCD Flat Panel...
I have a 22" Hannspree HF 237 monitor about a year
It is the inverter problem maybe it is loose or cold solder already. You better open the unit and look for the inverter section then re solder all leg parts there.
Regards;
votit
Feb 08, 2011 | Hannspree HF237HPB 23 inch LCD Monitor
Hannspree 20" Monitor HF205 - What is its' power
Max Resolution 1600 x 900 • 15000:1 Image Contrast Ratio • 5 ms Response Time • 34 Watt Power Consumption
techbelkin
Dec 13, 2010 | Hannspree 19" Widescreen LCD Flat Panel...
The 25 inch Hannspree LCD tv and monitor screen flickers.
Need code for hannspree 25" tv to use on a dishnet remote control
Sep 11, 2010 | Hannspree HH251H 25" LCD Monitor
Hannspree volume problem
hello:
also the setup from monitor the kan be set for loudnes
or check audio cable maiby failure
Aug 22, 2009 | Hannspree Computers & Internet
Where do I find a manual for Hannspree wide screen monitor 27.5"
http://www.hannspree.com/US/product_detail.aspx?id=23792&advancedkey=Size%3d28%22+Wide%2cCategories%3dLCD+Monitors&PID=
Feb 22, 2009 | Hannspree 28" Widescreen Flat-Panel LCD HD...
Hannspree will not supply XP drivers
i found a driver for my dell latitude d800 on dell.com. the download is r105341.exe. monitor works perfectly now.
Dec 15, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
Hannspree HC-194D 19" LCD Monitor Logo
65 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
