Question about GE Washers -- step-by-step repair manuals - WX10X114
Ge 175d2750g223 washing
Basket and agitator spin together
  • 1294 Answers
SOURCE: GE Washing machine won't spin in rinse cycle
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Posted on Sep 12, 2007
fanny
  • 146 Answers
SOURCE: Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Posted on Oct 31, 2007
  • 71 Answers
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
Posted on Dec 15, 2008
kram26
  • 544 Answers
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Posted on Mar 29, 2009
SOURCE: GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Posted on Apr 15, 2009
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
No spin - agitate
You just do this
  • Test the lid switch
  • Inspect the motor coupler
  • Inspect the drover belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
  • Inspect the Agitator
  • Inspect the pump coupling
  • Test the Water switch level
Good luck !!!
Regards
PCmania
Jul 08, 2009 | GE Washing Machines
Agitator problem
Check to see if any thing is under the agitator. If not then maybe the bearings going out or other part of machine . Besure the cap is tighten so agatator don't come off. Check for ware on agatator top to the tighting nut.
Jun 02, 2009 | GE WPGT9360E Profile Harmony 4.0 cu. ft....
GE Washer Model WJSR2080V3WW Agitates, Pumps, but will not Spin
I solved the mystery of the non spinning washing machine by GE. I pulled the agitator off and to my horror was a broken " hub". This the part in the middle of the basket under the agitator. The transmission shaft comes up through the center of it. Any way, it was severely broken and wedged in so it would not spin. Not sure if this is the only problem but I am going to buy a new machine. I can not get it unbolted to replace the hub and don't want to **** around with it. THANKS.
Jan 25, 2009 | GE Washing Machines
Spin Basket Spins Along with Agitatdor in GE Profile Washing Mach
if washer is newer version remove front panel and ck if has a gearcase it's probably bad if it has what ge calls a mode shifter it's probably bad it has a coil with connection to motor bd..look on bd for flashing green 4 flashes means open mode shifter coil
Dec 17, 2008 | Kenmore 24032\24036 Top Load Washer
GE 1996 top loader agitation but good spin cycle
check the motor, the timer,the water level indicator in side the machine on the basket it will have a tube with a little box attached to it. It may be clogged or malfunctioning.
Apr 27, 2008 | GE WDSR2080D Top Load Washer
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Agitator not spinning
could'be water level switch or timer control. another posibility is corrosion on the motor wiring connector
Jun 22, 2007 | Kenmore 24032\24036 Top Load Washer
Maytag Performa pav2300 spins slow does not agitate
My performa 2300 makes a loud screech when it stops spinning. What is going on?
Jun 19, 2007 | Maytag PAV2300 Top Load Washer
GE Washers -- step-by-step repair manuals - WX10X114 Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
