Question about Samsung DVD-V4600 DVD Player/VCR
Tray wont open,keeps saying it is loading but no disc is inside
4 Suggested Answers
  • 10 Answers
SOURCE: Tray Wont open
Hello All. Well, I just finished troubleshooting the same problem of one of my customers units. At first I thought it was the tray contacts but they were good. What I noticed with the cover off and the shield for the laser removed...BE CAREFUL NOT TO BREAK IT TAKING IT OFF ANF DON"T LOOK AT THE LASER...that if I moved the DVD motor, the motor that turns the DVD...it has a rubber wheel on the shaft...that the tray would open. The trouble was intermittent but I also noticed that the wheel would move when pressing the OPen button. I therefore concluded that the motor somehow was in the circuit to open the tray. So, I took the motor out CAREFULLY and on the end opposite the wheel there are two small holes. These holes appear to be access holes for assembly and to hold the brush contacts away from whatever they use for a commutator. At first i was going to disassemble the motor but changed my mind. I have contact cleaner spray and some old Color Tuner Cleaner spray from the old days of mechanical TV tuners. I gave each hole a small shot of spray and turned the wheel. Careful not to contaminate the rubber on the wheel as it is what grips the DVD and pushes it against the white nylon bearing. Voila, the tray opens and closes and the Load display is no more. As I said, be careful. If you are unsure...let someone who understands this stuff do it. Ed
Posted on Dec 27, 2008
welcomejee
  • 10594 Answers
SOURCE: My Samsung DVD-VR325 will not
Unplug dvd/vcr combo from wall socket for minute to get it reset, replug back in and turn it On and eject dvd tray.
If that does not fix the issue, let me know does disc tray moves little bit to eject or do you hear loading motor sound inside that ejects/ loads disc tray?
Thanks.
Posted on Sep 15, 2010
caroldon
  • 17130 Answers
SOURCE: everytime i play the disc,
Put in an ordinary audio CD and play to notice if the CD is detected. If yes the optical is working, if not there is no laser scanning and the possibility that the laser head can be defective.
Now certain cleaner disks will not be tracked to run for cleaning as it is not read. Hence it will reject. So it is ideal to clean manually the laser head eye using a cotton bud with gentle pressure on the lens eye.
If there is no result then watch if the CD spins or tries to spin. If so the board seems to work unless a test is taken on the main board but the possibility of a defective optical head can be the suspected fault.
If any of the above seems otherwise we must recheck with possibilities of a malfunction of the main processor board
Posted on Feb 09, 2011
Sony slv-350p dvd combo disc tray wont open
Might be to a broken loading belt, or damaged loading gear wheels. Check it. If gear wheel is faulty, it will be best to repalce the disc loading mechanism.
May 14, 2012 | Sony SLV-D350P DVD Player/VCR
Disk wont load keep saying open tray what should i do??
DO NOT ATTEMPT THIS WITHOUT BASSIC ELECTRICAL TRAINING, INTERNAL VOLTAGES CAN KILL!! That being said, sometimes you can open open the case, and reset the gears that open the tray, but usually the disc drive has to be replaced
Jan 12, 2011 | Microsoft Xbox 360 Console
My xbox keeps saying open tray I brought it to a guy twice and no fix everytime I put a game or movie in it it reads and says open tray
Reasons
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
May 08, 2010 | Microsoft Xbox 360 Console
Hello, when I put a game in the screen says, open tray. Wont reconize any games.
solution:
Mar 20, 2010 | Microsoft Xbox 360 Console
The xbox 360 elites keeps on saying open tray when trying to play
solution:
Feb 09, 2010 | Microsoft Xbox 360 Console
The xbox can't read the unscratched and clean discs
yeah, you can keep opening and closing it till it works or you can send it in to get it repaired. i tried every way possible to fix it, but i couldnt. something in the dvd drive has gone out and won't read discs the same anymore.
Dec 17, 2009 | Microsoft Xbox 360 Console
RCA RTD210
you should never use a disc thats scratched inside yiour machine its most likely your dvd machine is having trouble reading your media the best way to solve this is to unplug your machine wait turn it back on keep pressing eject it should eject dont use that dvd disc again hope this solves your problem did for me ;
Jul 31, 2007 | RCA RTD210 System
Samsung DVD-V4600 DVD Player/VCR Logo
Jerry Greenberg
Jerry Greenberg
