Question about Hoover Nano Cyclonic Compact Bagless Upright Vacuum, UH20020/W
Clogged hoover nano - Hoover Nano Cyclonic Compact Bagless Upright Vacuum, UH20020/W
I have a Hoover Nano Cyclonic that doesn't use bags. My daughter took the entire bottom apart because it wasn't sucking up. So she tried to clear everything and also TRIED to put it back together.
You may have a clog in there somewhere,
but still enough suction to pick some dirt up but it doesn't get sucked into the dirt cup and falls out when you turn it off. If your filters are over a year old or not maintained or cleaned frequently they may be restricting the air flow which can lead to clogs.
Jan 31, 2017 | Hoover Vacuums
How to replace hoover nano belt
Hoover Flat Vacuum Belt UH20020 Nano Upright 562633001
this is the belt you need
take off bootom plate and replace
Jun 20, 2016 | Hoover Vacuums
My hoover nano cyclonic just shut off
It has likely overheated. Let it cool down and see if it comes back on. If so that means something is causing an airflow restriction. Replace filters and check for clogs
Jan 22, 2016 | Hoover Vacuums
My hoover nano wont turn on there is no clogs it has been days with this issue yried diffrent oulets thru out my home
If it's over a year old, the motor probably is burned up. 90% of chinese made vacs only last 1 year. Take it to your local vac shop for diagnosis.
Dec 17, 2014 | Vacuums
Red light indicator comes on with suction only
Hi there Christy! It sounds like you possibly have a clog in your main hose. To check the hose for clogs remove the hose completely from the vacuum from both ends. Use a broom stick or something similar to loosen and remove any clogs from the hose. Remove the bottom plate and the brushes. Use a wooden spoon to gently break up and remove any clogs from the lower hose. Hope this helps!
Jun 16, 2014 | Hoover Nano Cyclonic Compact Bagless...
I have a Hoover nano cyclonic vacuum. I completely lost suction and found the hose was clogged to the max. After removing it and changing the filter I tried to use it and it picked up dust but not much...
If the hose was clogged there's a good chance the head was clogged too. Try to stick a bent coat hanger or other semi-rigid piece down the throat at the top of the head to push the clog out through the mouth. You might have to remove the beater bar to get the clog out.
May 20, 2014 | Vacuums
Can not find out how to register my Hoover Nano-Lite, on line.
Hoover may not be that sophistacated to have on-line registration. Use the card that came with your Hoover Vacuum. Make sure have the receipt to prove date of purchase.
Jan 26, 2009 | Vacuums
Hoover Nano Cyclonic Compact Bagless Upright Vacuum, UH20020/W Logo
32 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
