Question about Hoover Nano Cyclonic Compact Bagless Upright Vacuum, UH20020/W
Turns on but wont pick up anything. just is spitting out dog hair and dirt. how do i fix it
4 Suggested Answers
erickg
  • 116 Answers
SOURCE: hoover powermax s3530 spitting out dust
recently had same issue with friends. remove the filter and see the other thin filter there that goes to your motor compartment.. remove that and clean it. also check inside your tubes make sure not partially clogged.
Posted on Apr 17, 2009
  • 51 Answers
SOURCE: My wind tunnel had a lot of dog hair at the intake
I have an upright Dyson Cyclonic.  Because I have dogs, I also have a Miele Pull-along.  I use the cyclonic for fine dust after picking up the hairs with the Miele.
Much quicker in the long run.
Otherwise I would waste a lot of time cleaning out the Dysan Cyclonic airways.  I usually use long nose pliers to get the ball out and then I use my Miele to **** the rest out of the Dysans airways!!!
Posted on Mar 11, 2010
SOURCE: my vacum will not pick up, it is spitting the dirt
HelloHello Leslie,
First, check that the bag is not full, which would seriously restrict air flow.
Second, while the front cover is removed, check that the seal is not damaged or missing.
Third, remove the bag and disconnect the lower end of the convoluted plastic suction pipe from the the base of the machine (as for using the manual brush or tube) and check for any blockage or restriction to air flow; also check for similar blockage in the passage from the brush cavity to the pipe connection. Unblock as necessary.
Four, refit the bag and front cover, switch on the machine and check for suction at the bottom end of the pipe.
Five, if there is suction, reconnect the pipe to the base and check that the machine is functioning correctly. Make sure the brush roller is rotating and does not stop on contact with the carpet; if so, replace the drive belt.
I hope this is helpful.
Kind regards,
Jon Glenny.
Posted on Feb 11, 2011
Vacuum is not picking up dirt, dog hair, and lint! After 30 minutes use and I shut off machine it will not turn back on - machine is hot!
Blocked hose, filters, broken belt (If fitted) safety over temp device has operated turning the machine off. If it turns back on when it cools down, that gives you the answer. The motor could possibly be faulty as well.
Nov 19, 2016 | Vacuums
The beater bar is making a loud noise, and the dog hair is wrapping around the bar. Why would that be happening?
You probably have dirt or garbage wrapped around your beater bar. Loose carpet strings as well as pet hair will do this. If you see dog hair on the carpet its best to pick it up with your fingers as it will make a mess of a vac. Check your drive belt as it could be on its last legs as well causing the loud noise. Probably should be taken apart and belt replaced and a good cleaning as well. You should give a good cleaning once a year.
Nov 07, 2016 | Vacuums
We bought the Dyson DC66 a few weeks ago and all of a sudden it will not pick up dog hair or clean the carpets properly
The filters probably need cleaning. The filters on new Dysons block very quickly initially because of how much they pick up. Youll probably remember the feelings of astonishment and shame at how much dirt was picked up on first use. I know I was
Mar 03, 2015 | Dyson Vacuums
Miele upright dog and cat vacuum clogs easily and won't pick up pet hair
could be as simple as a broken belt or a clogged hose run a broomhandle through it or a plummers snake also check filters for dirt
Jan 05, 2014 | Miele Vacuums
Not picking up anything as well as it used to.
try putting new filters in, and check the hose for blockages,
Iain
Dec 23, 2008 | Eureka Capture Upright Vacuum Vacuum
I have a Eureka Whirlwnd bagless upright vacuum. It can pick up the dog hair but does not pick up the dirt anymore. What can I do?
Check the hose and dirt inlet by the brush roll for a clog. Also check your brush roll, do the ends turn freely, if not replace it, you may need a new belt, it may not be turning the brush roll under load. They stretch after awhile and will slip.
Apr 19, 2008 | Vacuums
Dog hair from vacuum is being laid back onto carpet
my plush carpet and dog hair do not go together! I realized with this particular model and in my environment, the bag fills in one vacuuming! I literally dug out all the dirt I could by taking it apart and then changing the bag. Voila!
Mar 31, 2008 | Hoover WindTunnel Widepath U5397 Vacuum
Vaccuum issue
If the dirt being vacuumed is not going into the dirt cup, then it must be just stuck in the hose and evenually will clog up. Check the hose and see it there is a clog in it, otherwise you have a years warranty on a new vacuum, take it into a warranty shop and have it checked out, take proof of purchase with you.
Oct 31, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Hoover Nano Cyclonic Compact Bagless Upright Vacuum, UH20020/W Logo
95 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
