Question about Sony CDX-S2010 CD Player
My radio keeps flashing through options and when i push and hold dspl it doesnt stop on clock it just keeps going through all the options
Setting clock radio Sony drive s XM car sterio
The clock uses a 24-hour digital indication. press and hold (sel) the set up display appears, press (sel) repeatedly until clock adg appears, press (dspl) the hour indication flashes, press the volume -/+ to set hour and minute, to move the digital indication press (dspl), press (sel) the setup is complete and the clock should start
Jun 21, 2013 | Car Audio & Video
How do you set the clock on sony xplod 100db+?
The clock uses a 12-hour digital indication...... Press and hold the select button...... The setup display appears...... Press the select button repeatedly until “CLOCK-ADJ” appears...... Press (DSPL...... The hour indication flashes...... Rotate the volume control dial to set the hour and minute...... To move the digital indication, press (DSPL...... Press the select button...... The setup is complete and the clock starts......
Jan 28, 2010 | Car Audio & Video
How do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
I don,t have the owners manual to instruct me to
Press and hold 'SEL' button. (the setup display appears) Press 'SEL' repeatedly until "CLOCK-ADJ" appears. Press 'DSPL' button. (the hour indication flashes) Pess the volume +/- button to set the hour. Press 'DSPL' button to select minutes, use the volume +/- to set minutes. Press 'SEL' button to start the clock. Press and hold 'SEL' ...setup is complete. To display the clock, press DSPL. Press DSPL again to return to the previous display. Reference page 4 in this link to Sony for your CDX-S2010 Operating Instructions.
http://www.docs.sony.com/release/CDXS2010.pdf
Dec 20, 2009 | Sony CDX-S2010 CD Player
How do you set the clock?
The Clock on this unit uses a 12-hour digital indication.
1.) Press and hold the SELECT button. (The setup display appears.)
2.) Press the SELECT button repeatedly until "CLOCK-ADJ" appears.
3.) Press SEEK +. (the hour indication flashes)
4.) Rotate the Volume Control dial to set the hour and minute. (To move the digital indication, press
SEEK -/+)
5.) Press the SELECT button. (The setup is complete and the clock starts.)
If this helps, please leave rating!
Oct 11, 2009 | Sony CDX-GT210 CD Player
Cant figure out how to set the time
1> Press and hold the select button. The setup display appears. 2> Press the select button repeatedly until "CLOCK-ADJ" appears. 3> Press (DSPL). The hour indication flashes. 4> Rotate the volume control dial to set the hour and minute. To move the digital indication, pres (DSPL). 5> Press the select button. The setup is complete and the clock starts. To display the clock, press (DSPL). Press (DSPL) again to return to previous display. The clock uses a 12-hour digital indication.
Jun 15, 2009 | Sony CDX-GT300 CD Player
All over sudden my boston horizon doesnt allowe increase the vol.
To fix: turn on unit, turn volume all the way down to 00, push and hold volume button for 10 seconds until beep then release, then turn volume all the way up to 50 (max) and push and release volume button.
May 17, 2009 | Boston Acoustics Duo-i Horizon Clock Radio
Clock set
try turning the radio off and hold down one the buttons until it blinks then adjust
Dec 29, 2008 | Sony CDX-R3000 CD Player
Sony cdx gt100 car radio/cd: how do I set the time?
1 Press and hold the select button. The setup display appears.
2 Press the select button repeatedly until "CLOCK-ADJ" appears.
3 Press (DSPL). The hour indication flashes.
4 Rotate the volume control dial to set the hour and minute. To move the digital indication, press (DSPL).
5 Press the select button. The setup is complete and the clock starts.
To display the clock, press ( DSPL). Press ( DSPL) again to return to the previous display.
Nov 19, 2008 | Car Audio & Video
Changing time on clock
right then...
switch unit off. (off button)
push and hold DSPL button for two seconds
the hour didgit should now flash
set the hour by useing the + and - select
when you have correct hour then push the SEL button then do the same for the minuites.
once time is correct then again press DSPL
Regards
Mark
Blue ICE
Feb 23, 2008 | Sony XR-C5100 CD Changer
Sony CDX-S2010 CD Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
