Question about Cross Century II Classic Ball-Point Pen
Who is inventor of the ball point pen - Cross Century II Classic Ball-Point Pen
Who is the inventor of the ball point pen
A Hungarian journalist named Laszlo Biro invented the first ballpoint pen in 1938.
Feb 11, 2014 | Cars & Trucks
Best way to fill in a deep scratch on car door caused by what I assume was a key...?
At Canadian tire they sell paint that comes in a pen type canister. has a ball point end and a brush. use the ball point end and just trace the scrtch with the paint pen. (exact match paint) this will hide the scratch well, but for best results. do a few coats. letting it dry between each time. which doesn't take long. and it will built the paint up flush to the original paint. when its dry. wash and wax over the surface.
Feb 16, 2013 | Cars & Trucks
I don't know how to change the time on my Chrysler Pacifica's digital clock.
If it's the round on near top of dash take a ball point pen and push the round circle next to the clock. If it's the one in the radio push button that says time then push the h button one the m button with ball point pen just like the top on before the display changes away from the time of day
Nov 04, 2009 | 2005 Chrysler Pacifica
Ibm 9513-ag1 flat monitor broken switch
I have the same monitor. I had the same problem you have. I couldn't find the correct replacement part so I improvised. The plastic part you refered to just activates a micro switch on the circuit board. In my case the micro switch worked just fine so I used 5 plastic buttons off of some ball point pens as a replacement. I took the monitor out of its plastic case and drilled holes in the front bezel directly over each of the 5 micro switches. I then put the buttons from the ball point pens in holes. So now the push buttons from the ball point pens act as a substitute for the broken part. I hope this helps.
Apr 20, 2009 | ViewSonic VA721 17" LCD Monitor
My Cross pen fell on the floor and won't work
was it a ball-point or ink pen tip???
if it is ball-pint. then all you have to do is get a refill cartridge from any of the office supply store or specialty shop.
if it is a fountain pen tip, then you have to send it back to cross for repair.
Feb 09, 2009 | Cross Pen Computers & Internet
Car wont shift out of park and blower motor quit.
Fuse #23 controls the turn signals, heater blower, reverse lamps, and the shift lever solenoid. There is a hole in the right side of the console where you can poke around with a ball point pen and unlock the shift lever. The fuse is located in a panel behind the glove box. I took my car to a dealer and had them change the fuse, but the ball point pen trick will save you a tow job.
Dec 26, 2008 | 1998 Ford Contour
My Tom Tom will not turn on
i have a tomtom go 510 and a ballpoint pen will not fit, i use a needle, i dont know if the 700 is the same but its worth a try.
Oct 28, 2007 | Tomtom GO 700 GPS Receiver
Cross Century II Classic Ball-Point Pen Logo
18 people viewed this question
Top Cross Office Equipment & Supplies Experts
Computer Links
Ivan
Ivan
Level 1 Expert
k24674
Are you a Cross Office Equipment and Supply Expert? Answer questions, earn points and help others
