Question about Panasonic TH65VX100U Plasma TV
TH65VX100U mount what is the mounting pattern
2 Suggested Answers
  • 864 Answers
SOURCE: Panasonic TC-P54S1 mounting hole pattern
See page 8 of the manual at: http://service.us.panasonic.com/OPERMANPDF/TCP42S1.PDF The bracket shown there looks like the mounting holes (4?) are vertical on the back of the TV. They may be identified by an arrow pointing to them. There will be two holes on each side of the TV centerline to attach the vertical components of the bracket that hang on the horizontal angle bars on the wall.
Posted on Oct 06, 2009
Can you tell me what size screws I need to mount my Toshiba Model 46G310U on a wall?
M6 or M8
http://support.toshiba.com/support/search?s_query=mounting+bolts
User Manual
Page 6
... stand. 3) Once you have removed all four screws holding the pedestal stand in place, remove the pedestal stand ..., level, stable surface that can support the weight of the surface. Four screws Hook Sturdy strap (as short as possible) 46 / 55" TV VESA Mounting Pattern 32" TV VESA Mounting Pattern Four screws Hook Sturdy strap (as short as possible) Four screws Hook Sturdy strap (as short as a quilt or blanket. Make ...) 200x200 mm 200x200 mm 400x200 mm 400x200 mm Screw Size M6 M6 M8 M8 (unit in mm) 40" TV VESA Mounting Pattern Removing the Pedestal Stand 1) Carefully lay the front ...
Toshiba 46G310U Mounting Screws
Sep 24, 2017 | Televison & Video
What is the mounting pattern for a lg 52lb9df-AD
I googled your model and it took me to a link that provides an owners manual to find the exact bolt pattern of the mount.
http://www.lg.com/au/support-product/lg-52LB9DF
Mar 30, 2014 | LG 52LB9DF LCD TV
Motor mount torque specs
Front engine mounting bolts 70-80 ft-lbs
Transmission mounting bolts 30-35 ft-lbs criss-cross pattern
Top engine mount bolt 45-50 ft-lbs
Engine/transmission bracket bolts 30-35 ft-lbs
Oct 26, 2013 | 2002 Harley Davidson FXST Softail Standard
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
I have a 32 inch ATSC/ALT3200N....Need a wall mount for it, and where to get same.
If you know what the Mounting comfiguration is... 200mm x 200mm etc. and the weight of the unit, then you can start your search...google search for the mounting size... i.e. "200mm x 200mm LCD wall Mount bracket"
that will get you started... then you can narrow down the search for the Weight supporting limitations.
your manual saids the hole pattern is:
Vesa standard (300x200mm)
Screw type: 4 x MB5x10
here's my search results:
http://www.google.com/#q=300mm+x+200mm+wall+mount+bracket&hl=en&prmd=ivns&source=univ&tbs=shop:1&tbo=u&sa=X&ei=yjx5Tf2vJZKw0QHL-ZzMAw&sqi=2&ved=0CFMQrQQ&biw=1015&bih=642&bav=on.2,or.&fp=86eb73c4baae05b0
Mar 10, 2011 | Televison & Video
I have the acer AL 1916w monitor behind the monitor there are four holes available . i want to mount this monitor on the wall . so pls help how will i mount on wall by using this hole or any possibilities...
They are Metric screw M4 or M5 from HD or LOWE's,
When you buy a wall mounting kit, it should come with the monting screw, do some research to what kind of mounting kit you are going ti buy that will have the mounting pattern that fit your monitor or if it has variable pattern that will accomodate your monitor.
User manula and support; http://support.acer-euro.com/drivers/monitor/al1916w.html
Watch out for caps going bad in your monitor also.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 20, 2010 | Acer AL1916W 19" LCD Monitor
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
Oct 06, 2009 | Panasonic TC-P54S1 54 in. Plasma HDTV
Panasonic TH65VX100U Plasma TV Logo
21 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
