Question about Refrigerators
Ice dispenser frigidaire
Frigidaire LGUB2642LE9 will not dispense water and is no longer making ice. Tried to replace water filter, but new water filter does not lock into place. Exact same model number and part number. There is an obvious difference in the top of the filters between the new and old. We have bought 2 new ones from two different places. The water filter light still shows the water filter is good though.
  • 87 Answers
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Posted on Sep 06, 2007
  • 92 Answers
SOURCE: 10 yr old Frigidaire ice maker stopped making ice
check to make sure the fill tube is not plugged with ice if it is not then i would guess the valve is shot
Posted on Oct 31, 2007
  • 1314 Answers
SOURCE: Frigidaire - FSC23F7DS - water dispenser not working but ice maker is
take out the crisper drawers and see if the water tank is frozen is the light on the dispencer lighting up when you depress the paddle and look up in the dispencer to see if the acuating paddis broken we will go from there
Posted on Feb 18, 2008
SOURCE: Frigidaire model FRS6LE4FW0 water dispenser does not work.
I DONT GET WATER OR CUBES
Posted on Jan 11, 2009
marka19
  • 1430 Answers
SOURCE: Our E522B Fisher & Paykel fridge no longer making ice?
Try the video on checking the F&P icemaker.
www.appliancehelponline.com/servicemanual.html
Posted on Feb 27, 2010
Water stopped coming out of the dispenser and it no longer makes ice. I checked water supply to the unit and everything was good. I have replaced the water filter.
Hello friend, thank you for your post!
From the information you have provided there is no water coming out of the dispenser or ice of your Frigidaire refrigerator. I see you have changed the water filter and still have no water flow. This could mean there is a clog within your water line or your water valve may not be pushing water into your refrigerator. You may need to seek assistance from a technician. They would have the appropriate tools needed for proper testing and disassembly of your refrigerator. This will help prevent any personal injuries or improper part replacement on your refrigerator. -Matt
Jan 04, 2016 | Frigidaire Refrigerators
Frigidaire GLRSF266J side by side makes ice, but dispenser won't work, what can I do?
The part that holds the switch in the dispenser door may have allowed the paddle to no longer contact the switch correctly. Look for a discolored wire connector under the hinge cover on the freezer door. If it looks all in order the water solenoid located where the water line attaches to the fridge may be bad.
Jun 28, 2015 | Frigidaire Refrigerators
Water dispenser on my 3 year old side by side FRIGIDAIRE PROFESSIONAL FPHS2386LFO is not working, It makes ICE but no water I can hear motor when I try to use dispenser
I appreciate your inquiry, bela_desousa!
From the information you have provided the water dispenser on your Frigidaire refrigerator is not dispensing. Have you recently changed your water filter? If you water filter has not been changed and is dirty or clogged it could lead to potential failure of your water dispenser. If the filter has been changed it could be a faulty dispenser. I would suggest consulting with a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
Dec 26, 2014 | Frigidaire FPHS2386LF Professional 22.6...
No water in ice maker and water dispenser
Good Morning Friend,
I understand your Frigidaire refrigerator is not making ice and not dispensing water. I suggest starting by changing the water filter in your refrigerator. You should be changing the water filter about every 6-8 months. If this does not work, I also suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try getting water out of the dispenser. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Frigidaire Refrigerators
Ice maker not working on Frigidaire frs26kr4a
I understand that the ice maker is not working on your Frigidaire refrigerator, model# FRS26KR4A. First, make sure the wire signal arm is in the down or on position. Secondly, make sure your household water line is open. Thirdly, make sure your freezer is cold enough to keep items frozen. Fourthly, check the saddle valve, if there is one, to make sure it is not clogged or restricted by any foreign material. Lastly, Check to see if the water dispenser is dispensing water. If no water is being dispensed, the water filter could possibly be clogged and would need to be replaced. Hope this is helpful.
-Best Regards-
WP
Jun 13, 2014 | Frigidaire FRS26KR4A Side by Side...
Water filter gets water but does not feed ice maker or water outlet.
Good Morning Joseph,
I see that you are having trouble with water dispensing and ice being produced on your Frigidaire refrigerator, even after replacing water filter, model# ULTRAWF, twice. I would suggest to reset your refrigerator, by either unplugging it, or shutting the power off at the circuit breaker for at least 2-3 minutes. Once power is restored try to get water out of the dispenser. If you are still having trouble with the water dispenser, remove the water filter and replace it, making sure you hear two clicks and the filter is flush with the filter housing. If these suggestions do not work, I suggest contacting your local authorized technician for further assistance.
-Best Regards-
WP
Mar 26, 2014 | Frigidaire ULTRAWF Frigidaire PureSource...
Frigidaire water dispenser won't work with new filter
The dispenser has a dual water control valves that control ice maker water and dispenser water. To find your parts you will need your refrigerators model number most time found around the fresh food sections door. Below I have a tutorial that may help you determine what may be the problem with dispensing water. Hope this helps, Thanks Sea Breeze
Oct 05, 2012 | Frigidaire Refrigerators
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Water dipsenser not dispensing any water
ONLY TWO POSSIBILITIES I CAN THINK OF IF ITS NEW COULD BE FREEZING IN THE DOOR LINER
IF NOT PROBOBLY NEEDS A NEW VALVE
Feb 18, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
47 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
