Question about Genie Company Genie Gwkp Keypad Replacement Cover Sandstone 35365t
Door will not close
Door opens with remote and switch but will not close
Make sure safety eyes are clean and aligned
Posted on May 08, 2014
Why wont my 3 remotes (hand held factory in remote)only work to open the door ? They no longer work to open the door.I did replaced the batteries and reprogramed, craftsman 3/4hp chain driven garage d
SOUNDS LIKE SOMEONE MAY HAVE PRESSED THE LOCK / VACATIONS SWITCH ON YOUR WALL CONTROL. IF STILL NOT WORKING AND THE LED IN THE WALL SWITCH IS NOT FLASHING TRY AGAIN TO PROGRAM YOUR REMOTES.
GOOD LUCK
STEVE
Dec 15, 2014 | Craftsman 3/4 Hp Garage Door Opener System...
Why does my 973LM liftmaster remote will only open door bur wont close it?
Most garage door operators (openers) have infrared safety "beams". The door won't close, even with a wired push button, if something is in the way.
May 10, 2014 | liftmaster Chamberlain Garage Door Opener...
How do you program a replacement key for a lexus es 330 2004
Here are the instructions from the factory manual. They must be followed exactly.
2004 ES330
1. Driver's door open, all other doors closed, key removed from ignition switch.
Within 5 seconds:
Insert and remove the key from the ignition switch twice.
2. Within 40 seconds:
Close and open driver's door twice.
Insert and remove the key from the ignition switch.
3. Within 40 seconds:
Insert the key into the ignition switch and close the driver's door.
4. Switch ignition ON and OFF:
A. Once to program a key remote transmitter code whilst retaining the original codes.
B. Twice to program a key remote transmitter code whilst erasing the original codes.
C. Three times to check how many key remote transmitters are currently registered.
D. Five times to erase all registered codes.
5. Remove key from ignition switch. System should now lock and unlock vehicle
once, twice or five times depending which mode has been selected. One to four
times, slowly, to indicate number of key remote transmitters registered.
6. Within 40 seconds:
Press and hold LOCK and UNLOCK buttons simultaneously for 1.5 seconds.
Within 3 seconds: Press any key remote transmitter button.
System should now lock and unlock vehicle once to confirm registration or twice
to indicate registration has failed.
7. Within 40 seconds:
To program additional remotes repeat step 60 now on each additional
remote you want programmed.
8. To exit programming mode open driver's door or insert key into ignition.
9. Step out of car with remote(s) in hand and test remote(s).
Nov 01, 2011 | 2004 Lexus ES 330
I have a Sears Model 139.53879 (3-Function Remote Control) garage door opener. It's about 12 years old. The remote controls open the door fine but the remotes do not close the door; it has to be closed...
Sounds like a problem with the safety photocells, to confirm locate the where the safety input is on the opener and bridge out the terminals ( not the supply voltage terminals) if the door then closes the photocells are the problem.
Mar 31, 2011 | Sears Genie Garage Door Gpwk12 Wireless...
Sears garage door opener 1/2 hp about 6 years old. Will not respond to remotes to open and close. Light flashes on opener when remote is pressed but no door action.
Door sensors are not working. Check if lights are on both sides.
Might be misaligned or one is bad.
Door will close if you hold in the garge close button until it's all the way down.
And it will open on it's own.
You can get these off ebay.
Jan 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door will open with remotes, but not with the wall switch
Sure sounds like the wall control is bad. Very common problem.
Jun 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door will not close
If you hold the wall button down and the door closes the problem is photo eyes.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Genie Company Genie Gwkp Keypad Replacement Cover Sandstone 35365t Logo
119 people viewed this question
Top Genie Company Home Security Experts
Lawrence Oravetz
Are you a Genie Company Home Security Expert? Answer questions, earn points and help others
