Question about Watches
How to set up cuckoo on diamantini and domeniconi clock
2 Suggested Answers
kaiserclock
SOURCE: Kaiser clock model kc-2.
remove the batheries and then advance the mintue hand slowly until you hear a clicking noice then remove both the hour and minute hand and place both at 12 oclock high postion advance the minute hand again to confirm you hear the click noise when the minute hand is at 12 and the hour hand is at 1. then replace batteries and the clock should cuckoo properly on each hour,,,,,best regards
kaiser clock
Posted on Mar 09, 2011
Cuckoo and action doesn't work
Is this a mechanical cuckoo, or an electronic? If mechanical, probably the strike mechanism is jammed. You might barely, HEED: just barely pull on the weight a tiny bit and see if this does anything. If not, time to get it serviced. If it is an electronic cuckoo, check batteries and contacts.
Nov 04, 2017 | The Watches
My clock will only run with added weight on the clock chain. I added the cuckoo bird weight to the clock weight chain and it keeps good time. If I remove the added weight it will stop.
I think your clock needs to be lubricated. A special light weight oil in a syringe will do the job. Just a little bit will Do.
Jun 23, 2016 | Watches
I need instructions for Acctim FELDBURG Cuckoo Wall Clock
Hi, not much info on this clock specifically. This might help though :)
Instructions Quartz Cuckoo Clocks
Jan 31, 2015 | Watches
I have a cuckoo clock . Time is 11 and the cuckoo chimes 8 times . What do I do? It's a non mechanical clock
If the clock is chiming like this it means that the hour hand is out. GENTLY loosen the hands, place the hour hand on the hour that the clock has chimed then fasten the hands in place. Gently move the minute hand clockwise Only, and check each hour that it strikes right. If the cuckoo has a button at the back use that instead. For more information email me at yvonne.finch@gmail.com
Mar 08, 2013 | Watches
Timing is off bad on the cuckoo part of the clock. It won't stop and runs till the weight hits the ground.
We had the problem with ours when I was a kid. What we did on ours was to turn the hands until the clock cuckoos. Then we removed the hands from the stem and placed them back at the correct time. Hopefully, you can remove the hands from the stem without a problem. Don't force it however. Good luck.
Feb 01, 2013 | Watches
How to sync. an old Black Forest cuckoo clock.
Suppose the cuckoo is calling three and the time is showing eleven, then to synchronize, simply stop the clock till the time is the same as the bird (three) and restart the clock at that time.
If the error persisys, then pull off the hour hand, and replace it at the synchonized time.
Jul 13, 2012 | Watches
I just got a Bradford exchange hour of glory cuckoo clock from a friend, I need to know how to make the cuckoo work, I installed batteries, wondering if there is something else to do or is it broken.
I am not familiar with the product you have. However, if this is a genuine cuckoo clock, driven by weights, the weights must be "wound", weights pulled to the top of their travel. If this is electronic, I would be looking for a switch. There also may be a electronic eye that prevents the sound at night. Can the eye see the light?
If you just got it, and if my comments don't apply, I am sure a quick call to the Bradford Exchange will solve your trouble, whether it is a step you inadvertently over looked or if the device if fault. I am certain they will help you.
Thanks for your question @ FixYa.com
Feb 17, 2011 | Watches
Kaiser clock model kc-2. The cuckoo doesn't go off on the hour and I want to know how to set it so the cuckoo will go off on the hour.
kaiser clock
Aug 04, 2010 | Watches
Cuckoo Clock
try to remove minute hand and replace back on shaft at a position 5 minutes earlier than what you removed it at
Nov 02, 2008 | Watches
Watches Logo
471 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
