Question about Husqvarna Garden
Install side cover on 455 rancher with chain break
I took off cover to install a new chain, now having a problem putting the cover back on, due to the break ring not going over.
    Master:
  • Husqvarna Master
  • 645 Answers
Problem is you removed side cover with chain brake closed. You must open the chain brake to re-install the cover. You can do it with the handle. Put the side cover into position, put the handle into the fitting on the side cover. push the handle forward until you feel the "3" point connector engage. apply pressure to the handle and pull back until the side chain brake "Pops" open. Your Husqvarna dealer has a tool to open the chain brake if you are unable to get it open. Takes about 5 mins.
Posted on Feb 03, 2016
spekgt
  • 60 Answers
SOURCE: 455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Posted on Aug 29, 2009
  • 251 Answers
SOURCE: Husqvarna 455 Rancher...
hi ,
by what your describing i think the chain brake has came on , you will have to reset this , its a good idea to carefully hold it in a vice and try to manually reset it
hope this helps
Posted on Jan 10, 2010
dontbother10
  • 2220 Answers
SOURCE: cutting with 455 rancher chain locked up took
Husqvarna - IPL, 455 Rancher/ 460, 2006-02, Chain Saw (example - may not be your saw):
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601076.pdf
See Detail A, pn 503 89 08-02. You can use a Crescent Wrench on one of the ears (left end) to reset it. With the cover positioned with pn 503 89 08-02 in the upper left rotate it CW until it nests, to reset it.
This works quite well:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
You can download the IPL for you saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I will wager you will NEVER again remove the cover with the brake set. Me either! Good Luck. HTH
Lou
Posted on Feb 26, 2010
dontbother10
  • 2220 Answers
SOURCE: cutting a log with 455 rancher chain locked up
HusqvarnaUSA.com
06 1500198
Lou
dontbother10
  • 2220 Answers
SOURCE: how to disengage or fix chain break on husqvarna
It sounds as though you have tried resetting the brake to no avail. If I were you any Monday through Friday at 1300 - 1500 I would be in my local Husky dealer (not Lowes). Someone familiar with the saw that can see and touch it. I suspect you will need parts once the problem is isolated, order them there and the diagnosis will probably be gratis. Factor in the shipping and handling fee and most dealer prices are competitive.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Posted on Apr 24, 2010
07 mcculloch 3516 has new bar and chain when running chain will tighten to the point it will bog motor down
Check your brake spring. It may be broken causing the brake to drag. Plus replace melted side cover.
Dec 06, 2013 | McCulloch Garden
Tip
How to get the chain brake reset so ou can get the sidecover back on
If you have removed the sideplate on your chainsaw with the chain brake in the locked position, you will have a very hard time getting it back on without destroying the brake band. If you have done this try this solution. First remove the bar and chain fronm the saw, then start putting the side cover on, use one of the nuts on the front screw.As it comes in contact with the ratcheting part of the hand break make sure you push the chain brake handle forward while tightening the front nut I mentioned. when the nut is snug, pull the brake handle back to reset the brake, You will hear it click into place. then remove the side cover and re install the bar and chain. your good to go/
on Dec 15, 2009 | Garden
Changing the chain on chainsaw
remove the 2 nuts holding the sawdust strut/sidecover and remove side cover. remove chain and bar. clean the chain slot and oil holes on bar. install new chain over bar and place remainder of chain over chain sprocket.back off chain tightener until chain and bar fit. reinstall side cover.
Nov 24, 2013 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Problem chain / break cover chainsaw
Hi, hold the cover in a vice where the bar nuts normally tighten up to, then pull the chainbrake lever back in the direction the handle bar would be. You will feel a click and the lever will stay back and the brake band will be released. Then refitted cover to the saw. Regards Phil.
Aug 20, 2012 | Garden
How do you rePlace the chain on the 455 rancher?
You take the chain cover off of the bar. It is two nuts. Take them off and the cover will come off. Slide the bar toward you and the chain will become slack. You can then slide off the chain from the sprocket. To put a new one on. You will need to turn the chain adjustment back all the way to the left. Then put the chain back over the sprocket, then onto the bar. Put the chain cover back on and tighten the chain back up. Then tighten the two nuts back to tight.
Apr 03, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
55 rancher-put new after market piston,ring and cylinder new sparkplug,cleaned carb,tried adjusting hi lo-new gas filter,new fuel line ,cleaned air filter-will start but on acelleration bogs and dies took...
I had a very similar problem with a stihl 029 farm boss.I did everything you did except I took it to a shop to do the piston and ring replacement. When I got it back the first time it would run for about two mins. then die.I fought it for a couple of weeks then took it back and expressed my displeasure. Then checked it all over and replaced piston and ring again and it runs great. They told me they could not get the right compression with the first one and thought the groove for the ring was cut to deep.I hope this is of some help to you. Thank you.
Mar 21, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
Removal of inner primary cover
For the cover you may have to loosen your shifter linkage to be able to remove it from the bike depending on what model you have
As for the inner primary you'll have to take off the clutch the front & rear primary sprockets and chain. You can loosen the bolts to both sprockets,then loosen the chain tensioner.
Slide the front & rear sprocket & chain off with the clutch still attached. leave them together and set it aside as one big unit.
The inner primary has bolts with bent washer tabs. Bend the tabs flat so you can remove the bolts.
Thre is a lock ring around the transmission shaft that holds the inner primary on too. Remove that with lock-ring plier.
Depending on your model, you may have to remove the rotor/flywheel first before the inner primary comes off.
Don't for get to put a new engine o-ring back on the front hole of the inner primary when re-installing.
Dec 03, 2010 | Harley Davidson FXST Softail Standard...
Bar thru the chain, pulled the side cover off with difficulty and now cannot get the side cover back on, appears the roundish bearing on the cover won't go over the round bearing that covers the chain...
I just had the problem of not being able to put the cover back on because the brake wwas engaged when I took it apart. What I did was use a #4 allen wrench and take the brake lever off being careful of the spring on the brake handle. There is a screw on both sides. I then put the cover loosely in a vise, and using the brake handle reset the brake to the correct position. It went back together easily. Probably took me ten minutes.
Oct 30, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husq 455 rancher chain saw. the chain locking spring in the cover is in the lock position and will not mount on the saw. how do i release the spring tension?
you should be able to release it with a flat screwdriver. you should see something that looks like a wheel where the chain brake locks to the brake handle when you put the cover back on. you should be able to twist that wheel and unlock it that way.
Oct 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
43 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
