My beko wahine machine wont drain
My brand new beko washing machine wont drain water
  • Washing Mach... Master
  • 744 Answers
This Beko washing machine video will help you
Buy Paul Beer
Posted on Apr 02, 2015
  • 351 Answers
SOURCE: beko washing machine
replace the timer not sure where you will get a service book from replace one wire at a time when you change the timer.
Posted on Mar 28, 2008
  • 25 Answers
SOURCE: beko washing machine wont drain or spin water stays in drum
the pump itself could be blocked or broken check inside pump first for any obstructions
Posted on Jul 16, 2009
  • 41 Answers
SOURCE: Washing machine won't rinse, drain or spin
COULD BE THE PUMP MOTOR GONE BUT FIRST CHECK THE FLUF FILTER IF FITTED
Posted on Jan 09, 2010
  • 6277 Answers
SOURCE: my beko washing machine has
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
(If these actions have not cured the problem, it could be the control board OR the main motor. Motors will show weaknesses when commanded to spin.)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 12, 2011
sodeep
  • 3267 Answers
SOURCE: beko not draining and spinning
This means to just restart the wash cycle. But I say the culprit is the lid safety switch. Make sure it is not stuck. This is the main reason washers will not spin.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Also must check water level device,if You do not know what is this or where is on machine then call a service.Maybe the hose is precipitate from device.
Posted on Apr 20, 2012
Water control valve washer
Hi carl if your Beko WM5140W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Mar 11, 2014 | Beko WM5140W
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
My beko wm7247w wont spin
Hi Tina if your beko wm7247w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Nov 26, 2013 | Washing Machines
Water wont empty from my machine
Hi if your beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Nov 04, 2012 | Beko WME7247W Washing Machine
My beko 1613 washing machine wont drain, and how do i operate the dial
Hi if your beko 1613 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
Mar 10, 2012 | Beko Washing Machines
Wont do final spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
you might find this test video helpful but only do it if you have checked the motor more beko test videos at site
Dec 02, 2011 | Beko WME7247W Washing Machine
Beko washing machine wont drain or spin water stays in drum
Jul 01, 2009 | Washing Machines
Beko w765s front loader wont spin
Hi if your beko w765s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Aug 20, 2008 | Washing Machines
Washing Machines Logo
106 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
