Question about Fusion FUS42DVD TV
I have a Rogers digital box and remote. Is there a code so that the remote can work the tv?
How do I find the remote code for my dynex TV?
Remote Control Codes For Dynex TVs ' Codes For Universal Remotes
codesforuniversalremotes.com/remote-control-codes-for-dynex-tvs/
  1. Cached
  2. Similar
5 digit remote codes for Dynex TV = 10463 11463, 11780, 11785 ... with a universal remote and work with Comcast, Dish Network, Direct TV, RCA, etc... Do you ...
RCA : Remote Code Finder : RCRN03BR : TV
www.rcaaudiovideo.com > Remote Code Finder
  1. Cached
  2. Similar
Durabrand, 10463, 10178, 10171, 11034. Dynex, 11463, 11785, 11810, 12049, 12184. ESA, 10171, 11944, 11963. Electroband, 10000. Electrograph, 11755.
Dynex TV Remote Control Codes
https://www.dynexproducts.com/remote-control-code
  1. Cached
Here is a listing of the most common Dynex TV codes for universal remote ... PHDVD5: 115; Phillips PMDVR8: 115; RCA RCU807: 135; Rogers DCT3250: 0463 ...
Universal RCA remote code needed for DYNEX tv [Solved] - Fixya
www.fixya.com/support/t8402745-universal_rca_remote_code_needed
  1. Cached
  2. Similar
Feb 22, 2011 - Hello Just buy one RCR 412BN, RCR 412SN or RCR 412SIN Universal remote control for your dynex tv. Codes are 11463, 11810, 12184. code for my dynex Google Search
Dec 22, 2016 | Dynex Televison & Video
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
https://forums.verizon.com/t5/Fios...Remote...Sound-Bar/td.../559715
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
redboard.rogers.com/.../your-remote-reprogram...
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
Need a remote code for fluid tv using rogers remote
Hi MiMi I attempted to search for the Code for your TV under several of the Rogers remotes and was unable to find one. You can do a general search for a code on any of them following some minor instructions. Navigate to link , choose the remote that looks like yours and then to the left will be choice to search all possible codes. Hope this helps. Good luck Rogers Cable Remote Support
Nov 04, 2014 | Televison & Video
Www urcsupport com
Use the auto code search function of the remote.
Apr 20, 2017 | Televison & Video
Programe sony rm-vl610 from rogers cable
This is the setup code for Rogers cable box. 0506
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jun 23, 2012 | Sony Televison & Video
Hi I am trying to program my Hitachi Plasma with a rogers provided universal remote. 5 button. I can program the TV but i cannot program the digital cable box. What am I doing wrong? Please help...
the sat and cable boxes are like DIY items , just use a known set top box like dreambox e.t.c. ,i have a problem with my Logitech remote and pace HD sat receiver,evrey 2 -3 the sat receiver changes remote codes :) and its very annoing, but ill switch to a LED tv with integrated sat so for know acceptable i have a tip for you regarding receiver -change mylar and ceramic caps to film ones
Mar 23, 2011 | Yamaha RX-V750 Receiver
Need codes for electrohome lcd tv so i can program it with my rogers hd box
i'm thinking you want to control your tv with the rogers hd box remote.
here is the link please click on the Remote Control Code-Finder
link on it and find your remote.
http://www.rogershelp.com/DigitalCable-Ontario/category.php?id=YY-24
Apr 15, 2008 | Televison & Video
Remote codes for a orion tv
These are codes used with Orion TVs
0713, 0115, 0105
Mar 01, 2008 | RCA RCU300WBL Remote Control
Remote control code
depending on the remote you have from rogers but the newest remote has 5 device's across the top we call it a 5 button there is a 3 and a 4 and a fat 5 button that is the old pvr remote all are pretty much the same in setting up easiest way is on 5 button remotes select the device ie. tv pres and hold setup untill light flashes 3 times enter 9-9-1 the with the tv on press ch+ button untill tv turns off once tv is off press setup to lock in the code test it by pressing tv then pressing power should turn tv back on if not repeat previous steps untill you get the right code some tv models are not compatible with the rogers remote 3 and 4 button pretty much the same except insted of a setup button you have to press and hold tv and select at the same time untill light flashes 3 times press 9-9-1 then press tv button untill tv turns off press select to lock into place
Dec 29, 2007 | GRIFFIN TECHNOLOGYTotal Remote-PDA Remote...
Fusion FUS42DVD TV Logo
22 people viewed this question
Top Fusion Televison & Video Experts
Lawrence Oravetz
ray gallant
Are you a Fusion Televison and Video Expert? Answer questions, earn points and help others
