Question about Canon PIXMA iP1800 InkJet Photo Printer
I have refilled my Ink Colour catridge, and now when I print documents the yellow colour can not be printed / come out..please help me
  • 159 Answers
The yellow print head is clogged or you are out of yellow ink. You can try to get it flowing with a warm wet paper towel by rubbing and and pressing it into the towel.
Posted on Feb 06, 2010
SOURCE:
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
Help w/ h/p deskjet 3520
hi/....
this is because of the low ink in the catridge. normally the colour catridge contains three colour in it. yellow ,blue and i think one more is pink. so in your case the other colours might have finished. so because of that you are getting only yellow. so please replace the catridge with new one and the problem wil be solved
Jul 15, 2010 | HP DeskJet 3520 InkJet Printer
Words are not printed clearly in black ink. strokes through them
Your black ink has finished, try and get a new black ink catridge, remove the black ink to get the no on the catridge. good luck
Aug 24, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Won't Print Yellow Ink
your yellow colour is used mostly please refil your colour cartridge or change your colour cartridge.
Jul 30, 2009 | Epson Stylus C44UX InkJet Printer
I changed my black ink and now i get the message left cartridge incorrect..how do i fix it?
HP PSC 2210 InkJet Printer. The following has to be done for checking the Blank Ink Catridge working : 01. Remove the existing Black catridge and Color Catridges from the Printer carefully. 02. Clean the location with a soft cloth with cleaning liquid to make the place dust free. 03. Put the correct black and colour cartridges recommended by HP and that too genuine one. 04. Do not use any refilled or reinked local catridges that will spoil the HP PSC 2210 printer. 05. Re-install the catridges both Black and Colour properly. 06. Take a test print out - both black and colour print outs. 07. Check the Printer status and there is no warning of Cartridges wrongly inserted. Have a Good day.
Jul 14, 2009 | HP PSC 2210 All-In-One InkJet Printer
I wish to clean the colour printing. I've cleaned
hello mvn 500 your printer is a inkjet say yes please remove the your colour catridge or laser printer please change the magenta ink only because laser was a 4 colour option cyan, magenta, yellow and black
Jul 02, 2009 | HP Hewlett Packard LaserJet 2605dn Printer
Print heads and test prints fine......will not print ay documents
I subsequently discovered that only black would not print - the other colours did. The following solution should work for any colour
Turn on the printer
Lift the front cover so that the ink tanks line up at the front
Move the grey arm to the right of the yellow upwards
Remove the ink tanks (in my case 4)
Carefully lift out the plastic holder for the ink tanks, this I believe holds the print heads
Clean the head(s) using cotton buds and injet refill ink cleaning fluid. I get mine from Tescos with my refill inks.
Replace everything and hopefully your printer will be o.k. Mine was
Jun 05, 2009 | Canon BubbleJet i560 InkJet Printer
Quality of colour
hi! there, well in connection to your poor printed color there posibility that ink was insufficient to distribute to you photo to print try to visit your ink status, black color is sepated to 3 color catridge.if there's a insufficient ink in catridge,replace or refill any thing as long there is much ink in your catridge,if ok and print still not good,try to clean your printer headdont use any thing to clean your printer herad,the printer will clean your printer head,on maitenance menu,click clean,try several time,also try to align your printer head,click aligned,t check the pattern of your printer,click pattern test.if ok try toprint if the color print is balance,try to print.check the preview before you print adjust the quality color as in yout tate before printing.regards and have a nice day.
Apr 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Refilled ink cartridges problem colour
this is not a printer problem, you have a problem with colour cartridge! u can fix this in 2 diferent way: 1. replace the colour cartridge with new one, or gently clean the nozzle cartridge with a wet tissue until the cyan colour mark a line on the tissue just like the others colours: yellow and magenta. maybe must repeat this several times.
Sep 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Printing b&w documents when colour ink has run out
The print will run with a full set of cartridges only- you must make the replacement.
Apr 30, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
123 people viewed this question
Clive
Clive
old marine
old marine
Ekse
