Haus washing machine
Power failure after 3mins working wont switch back on until 5mins has elapsed then switches back off after 3mins
SOURCE: GE washing machine, wont spin
Same problem (but without any smell). You should try to reset the two computer boards in the washer. You do this by 1) unplugging machine and wait for 30 secs; 2) plug in machine; and 3) open and fully close the lid at least 5 times. This resets computer boards, which can get messed up by power surges, etc.
Posted on Sep 04, 2008
SOURCE: lost the installation manual for a haus wm1050w
where can i get a manual for the haus machine
Posted on Dec 28, 2009
SOURCE: samsung washing machine F1245 control panel stuck??
I have Samsung/korea-SW905Washer.When power is switched on the Fault-'1E' appears. what could be the reason.( narrate list of control component failure).
Bought in the year 1996 at India ( voltas mega washer top loading-7.5kg) and working till last month.
after few wash cycles the machine stopped at aforesaid indication and it is not functioning due to above fault indication'1E'
provide me remedial measures or electronic control board circuit.
Posted on Jan 07, 2010
MakeupWizard
  • 39 Answers
SOURCE: washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Posted on Apr 22, 2010
ginko
  • 19396 Answers
SOURCE: GW709AU Smart drive.....Goes through the wash
Hi.
Unless the appliance is shutting down IMMEDIATELY after starting the drain part of the cycle, I don't think that you need a new pump.
If the pump turning on results in immediate shut down, then it is probably a short in wiring to pump. If the washer is failing after a while that the pump is on, then it can be the fan attached to (and part of) drain pump, present in F&P model, the timer board, or some other fault (eg. Balance sheet).
Other thing you can do is a diagnostic.There should be a tech sheet held in a plastic envelope tucked inside the control panel showing how to do the diagnostic.
Here general instructions to start Diagnostic Mode:
Turn off the power using control panel.
Press and hold the wash temperature down and then press the power button.
The machine will beep twice.
Browse diagnostic menu using the spin speed up or the spin speed down buttons.
If the machine does not enter diagnostic mode, then the control board may have a problem. The control board is expensive and fails rarely, before replacing the electronic control, any other part that may be responsible for the problem must be tested, including Power Control and Pressure Sensing Module and balance sensor.
In your case, probably is likely the pump, not the control board. The pump is tested by jumping its contacts and energizing it directly. If it fails after a while, then it must be replaced. For safety reasons the test must be done by a technician.
Pump is part 426956P, and costs about $60. Here the part.
Here the full disassembly in the part manual. Pump is part 18 in diag shown at page 16:
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 16, 2010
Start button wont work
check the door switch and check if the power comes to the panel. If not the switch is faulty. If the switch works but the panel does not start even after the push switch is working then it is possible that the processor is not working. check the working of the touch pad switch, this is also seen as a regular failure as this is the most used switch.
Sep 26, 2012 | Washing Machines
F&P intuitive washing machine says code 43
The out of balance micro switch under the brown motor controller board is corroded and needs replacing.
Aug 02, 2012 | Fisher and Paykel Washing Machines
Washer fills up but drum does not turn. After this part of the wash cycle has elapsed the washer will contniue normally with the rest of the wash (i.e. spin....). So not a fuse problem. Not sure of the...
If your motor does not run after the washer fills, then your failure is in the water level pressure switch, the timer, the drive motor or the wiring harness. The pressure switch would be the first component that I recommend checking. With the washer filled to satisfy the pressure switch, you can disconnect electrical power and pull the tan and violet wires off of the pressure switch. With a volt/ohm meter, measure the resistance across the leads of the pressure switch where the tan and violet wires were connected. You should measure near zero ohms of resistance with the washer full of water. If not, then your pressure switch would need to be replaced.
Jan 07, 2011 | Kenmore 43042 Front Load Washer
Washer does not start, no power, had power failure for 24 hrs after power came on washer will not come on, there is power in the outlet. is there an internal fuse or reset button, manual unavailable,...
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 09, 2010 | Washing Machines
Error code 07 on my Aqualtis AQXXF
Might be a bit complex but this is your problem and solution
REMEMBER TURN THE POWER OFF
F07: Heater relay stuck or element open circuit
This fault is only signalled when pressure switch is in empty position.
Check the efficiency of edge connector J3 on module.
Check wiring to heater and continuity of element (25 ohms approximately).
Check the efficiency of pressure switch connections and correct operation of pressure switch,
and the pressure chamber is not blocked with sludge.
Remove edge connector J3 and check wiring and contacts at positions 2, 3 and 4 on J3.
If all above OK replace pressure switch, module or eeprom as required.
Jun 10, 2009 | Washing Machines
Samsung washing machine F1245 control panel stuck??
May 29, 2009 | Samsung WE356A5W Washer/Dryer Laundry...
Wont start
No power
Lid switch
Mar 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Jammed door
turn it off all the way and its automatic timer will release after about 3mins
Nov 06, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
