Question about Keurig B60 Coffee Maker
Coffee grounds in cup from keurig
Coffee grounds in my cup of coffee
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
SOURCE: I cannot get a full cup of coffee from my Keurig
I HAD A SIMULAR PROBLEM...AFTER DESCALING WITH VINIGAR I NOTICED THAT MY COFFEE CUP WASNT ALWAYS SERVED FULL....THEN AFTER A LITTLE DIGGING ON THIS SITE IT BECAME OBVIOUS....I HAD A PIECE OF SOMETHING STUCK IN THE ONE WAY VALVE...SO TO SOLVE THIS I DISCONECTED MY KEURIG,BROUGHT IT OUT TO MY SHED AND CAREFULLY BLEW OUT THE THE ENTIRE UNIT WITH MY AIR COMPRESSOR BEING CAREFUL NOT TO USE TO MUCH PRESSURE AND BLOWING OUT A SEAL.....BROUGHT IT BACK IN,FIRED IT UP,WORKS PERFECT AGAIN...EVEN THE DESCALE LIGHT NOW STAYS OFF.NO MORE PINCHING THE RUBBER RETURN VALVE IN THE RESIVIOR JUST TO BREW A CUP OF COFFEE. HOPE THIS HELPS SOMEONE........................
Posted on Jun 14, 2009
SOURCE: My Keurig B60 is Suddenly Brewing WEAK Coffee
I don't have a solution but have just experienced the same problem and am baffled. I am using the same beans same grind. In fact using the exact same grind it went from great one day to weak the next day.  I always run it for 15 - 16 secs to get the shot and that hasn't changed. Pressure and temperature appear fine. I cleaned the top of the top filter which was a little dirty but not seriously bad - no change. The coffee flow which is normally chocolate coloured to start with is just mid brown.
Posted on Feb 28, 2010
cmccune04
  • 213 Answers
SOURCE: Missing Keurig part
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Posted on Apr 13, 2010
SOURCE: when i put the coffee cup in the keurig....nothing
use a small needle, paper clip or pipe cleaner and run it up into the "needle" section under the lid that pierces the top of the cup. The problem is one you will have often as coffee grounds get up in there and dry between uses and clogs the hole.
Posted on Jul 09, 2010
Everytime I put in Keurig pods in my keurig I get coffee grounds in my coffee cup and all over the coffee pot.
If cleaning the puncture pin hole doesn’t work, and you have thoroughly cleaned out your machine, look at the bottom of the particular K-cup you are using. Many of them have an indent in the bottom, and these cause an issue, allowing rounds to escape. Unfortunately, this particular type is not always compatible.
Sep 08, 2017 | Keurig Coffee Makers & Espresso Machines
The single cup server runs over and grounds go everywhere.
Bottom needle is plugged...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Aug 30, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
My k cups are shooting coffee grounds everywhere!
heatman101
Aug 26, 2011 | Keurig B60 Coffee Maker
Coffee overflows and grounds sit on top of pod
heatman101
May 18, 2011 | Keurig B60 Coffee Maker
When i brew a cup of coffee with my Keurig coffee maker there is a lot of coffee grounds that do not filter. Its like drinking dirt. How do I fix my issue?
heatman101
Nov 08, 2010 | Keurig Elite B40 Coffee Maker
When I brew a cup of coffee there are coffee grounds in the coffee?
Take your K-cup out and it splits into two pieces. The buttom half has a chamber where coffee grounds that slip out can sit. When it builds up you tend to see allot of grounds in your coffee.
Also check that your top needle seat is there and in good condition.
If you need assistance further my email is help@igotsweetdeals.com and my site which sells keurig parts is http://wwww.Igotsweetdeals.com/
Hope I helped you!
May 12, 2010 | Keurig B60 Coffee Maker
Keurig machine releasing coffee grounds on top of K cups
I have the same problem but if you take a paper towel and clean the grounds from the top each time it helps. Cleaning around the little point that pierces the cup. It helps but doesn't completely eliminate the problem.
Jan 04, 2009 | Keurig Elite B40 Coffee Maker
Keurig B60 Coffee Maker Logo
13 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
