Wiring diagram for model dp42840 nov2010 - Televison & Video
The screen is blank
hi sorry to say but the bulb is gone or check the wires at the back of the screen,,
May 18, 2013 | Sanyo Dp42840a
Sanyo tv standby mode
Too little details here - need model, chassis, more specific behavior details.
This may help:
http://blog.coppelltvrepair.com/2012/07/sanyo-dp47460-dp42840-dp46819-and.html
May 06, 2013 | Sanyo 42 in. LCD TV
I need to replace screen on my sanyo tv model #DP42840
If screen (display panel is bad, cracked or damaged in any way the cost of the part will exceed the cost of this set when new or even the cost of a new set to replace it.
May 23, 2012 | Sanyo Televison & Video
To replace screen on sanyo model number DP42840
May 23, 2012 | Sanyo 42 in. LCD TV
Pulsar 180 engine heating very soon and sounds loud
Check the oil level. An oil change should be carried out anyway about every 6 months, and filter change every 12. All dependent on the amount of use it gets.
Apr 28, 2012 | Bajaj Motorcycles
Just purchased new Sanyo 42"DP42840.
Being a new set it is important that you should have tested the model to your liking in the showroom. However some of these models have poor sound as the sound is normally fed into the home audio system. So if you have any audio system connect the audio outputs to the auxiliary and you will be able to get better sound.
Other wise you need to check back at the showroom if the same model sound as same as yours. Otherwise exchange the set under warranty.
Mar 30, 2011 | Sanyo Televison & Video
My sanyo dp42840 flat screen turns off by itself after 5 minutes...what do I do?
The first thing I would check would be the electrolytic capacitors on the power supply board. If any of them are swollen or domed on top rather than flat, they will need to be replaced and that will fix your problem. I fix about 75% of them at the shop by replacing caps on power supply. A tech will probably charge around $100 if it is bad caps. It is a fairly easy job.
Jul 31, 2010 | Sanyo DP42848 LCD TV
Televison & Video Logo
19 people viewed this question
Top Televison & Video Experts
Electro Med Services...
