Question about GE (ZDWR240PBS) Wine Cooler
I have a GE wine cooler. The compressor will not run. Lights and condensor fan operate. checked Ohms between the 3 electrical pins on compressor. Accross bottom is 10 ohms, left side/bottom to top is 6 ohms, top to right side/bottom is 4 ohms. Starter relay does not rattle when shook Overtemp device shows continuity
  • 54 Answers
SOURCE: GE Side By Side Stopped Working
Either a bad interface\display board or a bad main computer. I would try the main computer first.
Posted on Jul 03, 2008
  • 1462 Answers
SOURCE: refrigerator warm on top, cold bottom, blower fan top of freezer not turning
check continuity thro the fan motor and check it is free to turn. also check if power is present at the fan
Posted on Oct 13, 2008
  • 19 Answers
SOURCE: My GE Profile wine cooler temp does not respond to any temps
Call GE answer center 1-800-626-2000 ask for tech help,have Model # off data plate ready.
Posted on May 09, 2009
rylee_smith
  • 8619 Answers
SOURCE: ge side by side profile. freezer works fine, all
Hi!
First of all you need to clean the coils (condenser coils under the unit or evaporator coils inside the freezer). The coils inside could be iced over because of failure of defrost system. Now check that the condenser fan under the fridge is working properly. Check that the fan in the freezer work which pulls cold air from the coils inside freezer and blows it to the fridge side. Are the temperature control knobs in the fridge adjusted correctly? It actually just opens a vent to let more or less cold air in from the freezer. It takes a while for the ice to build up in the freezer enough to affect the cooling.
My first guess would be the defrost timer. You can manually turn it to engage the defrost cycle and observe whether or not the defrost heaters come on. Now use a hair dryer to speed up melting the ice when there is lots of ice buildup. Most timers are 24 hour timers. It will turn the defroster on every 6 or maybe 12 hours depending on the model.
Before testing the defrost heater, unplug the refrigerator to avoid an electrical shock hazard.
The defrost heater is usually located at the back of a side by side freezer or under the floor of a top freezer. It will be necessary to remove obstructions such as the contents of the freezer, freezer shelves, icemaker and the inside rear or bottom panel of the freezer.
The heater is connected by two wires. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 24, 2009
aasc
  • 1606 Answers
SOURCE: compressor stopped running in GE GSS25KGMC WW side by side
Remove the main control board , and look on the soldered side , behind the small black boxes . You will be looking for a " bullseye" which is a pin , where the solder has become unsoldered around it . If you find it , resolder and it should work . If all solder joints , behind the boxes look ok , then replace the board .
Posted on Nov 27, 2009
Testimonial: "aasc was very helpful with his direction and through his help I was able to make the repair! I'm very grateful for him taking his time to reply."
Wine fridge is not getting cold anymore
Its really hard to determine without proper diagnosis, but are you sure it indeed has a compressor? does it run ? Does it have a circulating fan inside? A lot of the wine coolers I've dealt with were "Peltier" coolers. They use electronics to cool usually only to about 10deg below room temp. They require a load ( in this case wine bottles ) to operate properly. They don't have a cold control like a refrigerator.
Jun 30, 2014 | Koolatron KWD28SN 28 Bottle Compressor...
My GE GSL 25JFPABS Refrigerator failed yesterday. No Comressor no evap or condensor fan
Fan motor starts with the compressor. Sounds like you need a main board and condenser fan motor. Call GE. It might be covered under warranty. A known issue with certain models. You will also need serial # if you call.
Mar 23, 2017 | GE Refrigerators
It just stopt cooling (wgersdorf@yahoo.com)
Turn the temperature dial to the lowest temperature setting. Wait 24 hours for the wine cooler to reach the desired temperature. Also, turn the wine cooler off and inspect the fan. If the fan if it's running or not.
Lastly, check the compressor.
These are the areas that could make your wine cooler stop cooling; the temperatue settings (Thermostat), then Fan and the compressor.
Check these three areas and let me have a feed back.
Bye for now.
Mar 04, 2011 | Haier BC112G Wine Cooler
Doesn't cool and i am assuming that means the condensor. How much to fix. it is two years old but with very little use , looks brand new.
clean coils front and back....clean drain oil fan motor...take cover off relay...clean plugs and pins( from oxide)...if it starts hard get a har d start kit for compressor
Aug 28, 2009 | Danby Silhouette DWC512BL Wine Cooler
The compressor and the fan don't run.
its your contactor or the wire feeding it
Aug 16, 2009 | GE ZDW24A Wine Cooler
The refrigerator unit isn't operating. Lights
check defrost timer stuck in defrost advance with screw driver if it starts replace timer they hide them all over may be in fridge or by compressor ,,behind toe kick..anywhere box shape 5-6 wires on it...just keep looking it's got one somewhere
Aug 16, 2009 | U-Line 2015WC Wine Cooler
I just bought a wine cooler not sure where to start to fix it. Fans will not turn on
Hi there.........i take it this is a used / second hand wine cooler......if so you've probably discovered why its been discarded........problem could b due to a faulty compressor unit....the fans are usually wired through the compressor...and run in conjunction with it........if the compressor isnt running then the fans are out .........if the comressor is running then check that there is nothing impeeding the fans rotation.....check for broken or damaged wiring.....check for tampering by someone else....check continuity of wiring through fan coils.........check for faulty starter unit on compressor
regarddss ir Galahad
Aug 12, 2009 | Haier BC112G Wine Cooler
Does not cool the wine,back panel is warm and unit is making a no
If your condensor fan is running and the compressor is running then you will need a tech to look at the sealed system for you.
May 26, 2009 | U-Line 15WC Wine Cooler
Brand new out of box and will not cool - after 12 hours - compressor is very hot ?
First question is, are there any fans that are built in that are not running? next is there may be no freon in the unit. Ive seen new stuff from the factory have no freon inside. feel the suction line (the bigger one) from the compressor. It should be cool. The discharge line (smal one) should be hot.
Dec 23, 2007 | GE PWR04FANBB Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
GE (ZDWR240PBS) Wine Cooler Logo
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
