Question about Tefal T-fal Actifry - FZ7000002
Broken power supply pin - Tefal T-fal Actifry - FZ7000002
PC Power Issue
If it only comes on when you move the cables but not if you don't then one of the cable connections (pins) are loose or internally broken. Unplug it and check each cable/pin for any loose connections, bent pins etc.
Nov 09, 2014 | CORSAIR CX Series Modular CX750M 750W ATX...
My power suplly is broken and i cant use my xenyx1002fx. can i order a new one?how mach it cost?
Broken pins are common on these power supplies. The units are hard to find. If yours only has broken pins in the connector, find the connector type and have it replaced. Fifeteen minute job...
They probably use MINI DIN types available from Digikey.com or Mouser.com.
May 30, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
The adapter for my micron pc transport gx3 is not
Power cord is available in electronics stores, go there you find-it
Nov 29, 2009 | MPC Computers MicronPC power supply - 220...
No power to motherboard
Could be one of these:
1. Lead Fuse could of blone
2. Fan broken
3. Insted of the power, it could be your motherboard
4. THE WHOLE THING
Im sure your get it fixed soon and i hope me telling you what it could be has helped you.
DigicalJAI
May 19, 2009 | Okia / 450-Watt / ATX / 80mm Fan /...
The pin that the power cord goes into has broken off
Is the cord broken in the computer, or the monitor or the pin broken and stuck in the machine? If it is in a desktop it goes into the power supply. Which you can change the whole power supply fairly cheap. that is if it in a desk top computer. 4 screws, 4 or 5 connectors and ta da new power supply, All you need is readings off power supply such as wattage. Good luck
Mar 10, 2009 | Acer TravelMate 2480 Notebook
Have Dell E210882 MTB and need pwr-switch pin locations
No, don't automatically assume the mobo is broken. Look closely at all the pins. There should be a 4x2 rectangle of pins, maybe coloured. They'll say things like 'PWR-SWTCH' and 'çPU-LIGHT'
Connect those up, and your mobo manual should have specific details on what goes where.
Dec 15, 2008 | Dell (E210882) Motherboard
HP Compaq nx7300. Pin has broken off from the power cord supply. Mains input cord now won't work as part of pin is possibly stuck inside. Took to original supplier who quoted £220 to replace entire...
absoloutly not!!!!! if the pin has broken in the external power cord and not inside the PC itself then all you have to do is replace the PSU ( power supply unit ) and the lead, this should cost you no more than £35 and its easy to replace yourself
Nov 18, 2008 | HP Computers & Internet
Power supply
ATX Version 1.2 - 20 wire motherboard connector Pin 1 Pin 2 Pin 3 Pin 4 Pin 5 Pin 6 Pin 7 Pin 8 Pin 9 Pin 10 3.3V 3.3V Gnd 5V Gnd 5V Gnd P_OK 5VSB 12V Oran Oran Blk Red Blk Red Blk Gray Purp Yell Oran Blue Blk Green Blk Blk Blk White Red Red 3.3V -12V Gnd P_ON Gnd Gnd Gnd -5V 5V 5V Pin 11 Pin 12 Pin 13 Pin 14 Pin 15 Pin 16 Pin 17 Pin 18 Pin 19 Pin 20 The color scheme used for the voltages in the 20 pin connector holds for the other ATX standard power supply connectors. However, brand name manufacturers often build proprietary power supplies or make up their own color coding, so I wouldn't throw out a power supply that supplies 5V where you think it should supply 3.3V. It's more likely a proprietary design than a failure.
Feb 21, 2008 | Computers & Internet
No power
check your power supply and make sure the proper power at the ends and the light is on the power supply, I no those C640 s have a problem with the darn plug in and the pins in the laptop may have got bend or broken check that out and if all the pins are not bent. your power supply may be bad check that out, if so you can go to Dellsupport.com and order one for fairly cheap. I think that will fix your problem.
Dec 21, 2007 | Dell Latitude C640 Notebook
Tefal T-fal Actifry - FZ7000002 Logo
29 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Gerry Harvey
Gerry Harvey
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
