Question about Sonic Impact Technologies Sonic Impact T24 Deluxe iPod Hi-Fi Sound Dock Docking Station
Will sonic impact T24 play and charge iPhone 4
5 Suggested Answers
  • 3 Answers
SOURCE: my sonic impact technologies sonic impact video 55
If you have a later IPod, 6th Gen or later, Apple changed the software and Sonic Impact no longer plays your movies, but audio is fine. You can get around this by purchasing, from Apple, and adapter cable. It is $50 but allows you to charge your Ipod and play your movies on your home TV. The cable is really just a key that unlocks the TV Out setting. If you have and 5th Gen or earlier then you probably just need to go into video setting and select TV OUT : ON. I hope this takes care of your issue.
Posted on Dec 03, 2009
  • 3 Answers
SOURCE: I have a sonic impact technologies sonic impact
The battery is rechargable for about 400x. If you leave it on the charger too long or never let the battery run down it will shorten its life span. Sonic Impact no longer sells the replacement battery unit through their website and I have been looking for replacements myself. the problem is this: the battery unit is integrated with the battery cover and can not be separated. So you need the actual Sonic Impact battery, and they have not responded to any emails, requests for customer support or phone calls. Good luck.
SOURCE: Sonic Impact iF2 Not charging
Hey how do I find a replacement battery for the Sonic Impact I F2?
Posted on May 18, 2010
SOURCE: sonic impact i-f2
There is no sound when I place my IPOD in the Sonic Impact F2 docking station. I can power on and off the Sonic Impact system with the remote control, however cannot change track on Ipod or nor sound? any idea as to why this is happening?
Posted on Jun 18, 2010
Iphone 3g proper charging
Once you purchase the iphone,dont use it yet.Instead of using it right away,kindly charge your IPhone with the wall charger for 3 hrs.Please dont use the Iphone while charging.Kindly check always if the battery is full.Once its fully charged then that's the time that you can use the iPhone. Once fully charged, let the iPhone's battery fully drain.Please keep the iPhone off for 2 hours.Fully charge your iPhone and allow the battery to rest in the fully charged state for two hours. (You may use your iPhone during this time as long as the iPhone is plugged in).Repeat the third and fourth step a maximum of three times if you feel your battery indicator is inaccurate.
Here are some tips for your everyday charging for your IPhone:
#1 - Charge your iPhone throughout the day when available. Charge EVERY night, regardless of charge level. This will keep your battery active, which is healthy for the iPhone's battery.
#2 - Use a wall charger or car charger w/ rated output 5V 1A. Computer chargers might not charge when the computer is in standby mode.
#3 - You cannot overcharge your iPhone. You don't need to disconnect the iPhone from the charger after it's done charging. Once fully charged, the iPhone will run strictly off of AC power and will not damage the battery.
#4 - Every two months, make sure you fully charge and fully drain the battery, in one cycle. This calibrates your battery indicator. If you fail to do this, your indicator will become inaccurate. Calibrating your battery does not improve battery life.
#5 - If you ever need to store your iPhone for any reason, make sure your battery is stored @ roughly 50% and in a cool environment.
#6 - Always charge your iPhone out of its case (assuming you can easily remove the case). Charging your iPhone inside your case will make the iPhone hotter, which is bad for the battery.
#7 - Charge your iPhone in a cool location. Charging your iPhone in a cool environment has a tremendous impact on your battery's lifespan. The colder the location you use to charge, the more charging cycles you can complete without your battery deteriorating. Avoid charging in direct sunlight.
#8 - Use properly rated chargers. Using chargers that are not properly rated will have a huge impact on your battery's lifespan. Make sure your car charger has the same rating as the official Apple charger.
The official Apple wall charger is rated as follows:
Input: 100 240V ~ 50/60 Hz 1.0A
Output: 5V 1A
Thanks!
Apr 15, 2011 | Cell Phones
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
The sound has stopped working on my sonic impact I fusion and I have no idea why please help
the part were my ipod plug into Sonic Impact i-Fusion is very loose and at times will not play music- I need to put presser on the ipod to play music - how can I fix this loose ipod plug in?
Aug 24, 2010 | Sonic Impact Technologies i-P23 Portable...
I have a sonic impact technologies sonic impact video 55 and it want come on and it want take a charge what wrong with it
Nov 11, 2009 | Sonic Impact Technologies Sonic Impact...
My sonic impact technologies sonic impact video 55 can not play my movie I don't not why. I hear my musie but can not see my movie on the screem. what can i do
I have a Sonic Impact V55 Video player and a new 160GB Ipod. Anyway to get the video to work on it?
Absolutely, I have this myself. My 5th Gen works great, but the 160GB would not show movies, just played music. Apple has an adapter cable set that allows you to hook your Ipod to your TV. $50 buy it! You can charge and watch your stuff on your flat screen. It also unlocks your Ipod TV out setting for your Video 55. Set you IPOD video setting to TV Out: on, select your movie and play. Plug in the IPOD nip to your Ipod then set your Ipod into the Video 55. A bit of a pain but works flawlessly. If you select a different movie you have to do this all over again.
Oct 30, 2009 | Sonic Impact Technologies Sonic Impact...
May 07, 2009 | Sonic Impact Technologies IF22 Docking...
My Video 55 player will not play my videos
You need to switch the video out seeting on the iPod, simple. It is located in Video/video settings/TV Out. Change the setting to "On". Problem solved. However, if you have an iPod that is less than 1 year old, nothing will work, iPod blocked this ability to change to "On" and is set on "Off" permanently.
Mar 04, 2009 | Sonic Impact Technologies Sonic Impact...
IPod is not charging when docked.
my 6 generation nano will not play on my i-f2 sonic impact portable docking station, can any one help?
Jan 07, 2009 | Sonic Impact Technologies IF22 Docking...
Sonic Impact Technologies Sonic Impact T24 Deluxe iPod Hi-Fi Sound Dock  Docking Station Logo
23 people viewed this question
Top Sonic Impact Technologies Audio Players & Recorders Experts
 Grubhead
Grubhead
jscuin6
Tom Chichester
Are you a Sonic Impact Technologies Audio Player and Recorder Expert? Answer questions, earn points and help others
