Royal ag55x won't turn after bits of paper are cleared out.
I have royal px110mx and it won't shredd my papers. When turned on and put a paper, it will be making noise and not shredd the paper. Can someone bail me out.
Your Royal shredder probably hasn't been cleaned since the day it was first used. Take a look at the shredding mechanism and you will find bits and pieces of everything. A thorough cleaning should get your shredder working again. Be prepared to spend considerable time on maintenance.
Jul 20, 2016 | Royal Office Equipment & Supplies
How do I remove paper stuck in my shredder????I have a Royal 10X Cut Paper Shredder. On label it has PCUA:29054E 10x 00324040. How do I take it apart to remove the wedged paper???
You may have to turn it upside down and go to work with tweezers and a utility knife to remove every bit of paper from the mechanism. I have found that 10X rating to be overly optimistic; the equivalent Royal shredder I am using currently groans and complains if more than a few sheets are fed in at a time.
Feb 22, 2015 | Royal Office Equipment & Supplies
Royal sc120 shredder wont run.. Paper jammed in head and cannot remove it--no reverse or forward will work.
This is the most common problem..."too much paper".
If it won't go in either direction the only option is to open the cutting head of the machine(after unplugging) and to manually try to turn the gears to un-clog the paper.
Once you have cleared the paper from the cutting blades see if it still turns...see if any plastic gears have been damaged. Plug it back in and see if it runs...if it dosn't you may have blown the PCB in which case you should contact Royal at 1-800-524-0799 regarding replacement parts.
Jun 14, 2011 | Office Equipment & Supplies
My royal sc120 shredder will light up but there is no sound will not run. I have cleaned out clogged bits of paper. What could be wrong?
Shredders have a reputation for being very unreliable...they often just quit like that...
You can try also to blow it out with a can of compressed air, but it probably won't help... not much else that you can do...
heatman101
May 27, 2011 | Royal Sc120 Shredder
Broken gear prevents shredding
Contact Royal for parts assistance at 1-800-524-0799.
Jan 05, 2011 | Royal AG55X Shredder
Royal 435dx - PE error. How do I clear it?
It means printer error. Make sure you don't have paper jammed in the printer, then turn off and on at the wall. -------------------------------------------------------------------------------
If anyone needs a Royal 435dx manual, try here:
http://the-checkout-tech.com/manuals/cashregisters/royal1.php
Jun 30, 2010 | Casio Parts Cash Register PC Desktop
Cash register PE ondisplay and nothing will work
It means printer error. Usually after a paper jam. Clear any paper out and try turning off and on at the wall. ***************************************************************************** *****************************************************************************
All of these manuals can be downloaded at: http://the-checkout-tech.com/
royal 110cx User royal 115cx User royal 130cx User royal 425cx User royal 435dx User royal Alpha-580 User Programming royal Alpha-583cx User Programming royal Alpha-600 User Programming royal Alpha-600sc User Programming royal Alpha-601 User Programming royal Alpha-710ml User Programming royal Alpha-9155sc User Programming royal Alpha-9180sc User Programming royal TS4240 User Programming
Mar 02, 2010 | Office Equipment & Supplies
The shredder has been unplugged from power for a couple of weeks. I clean and clear paper bits from rollers and plug it in to outlet(with power). It doesn't have an on light and doesn't turn on.
Most common prob with "consumer" machines is that people put "too much" paper in them and JAM them...then if they don't unplug the machine to let it "cool-down"....by which time the machine "fries" the pcb inside.
For parts advice give Royal a call at 1-800-524-0799.
Feb 14, 2010 | Royal 29140X PX100MX Cross-Cut Shredder
Royal 85X Paper Shredder not working
I have a Royal 10X. Check for a faulty bin interlock.
Feb 01, 2018 | Royal 85X Shredder
Shredder not stopping
Defective input sensor switch
May 26, 2007 | Royal 1280MX Shredder
k24674
jasbo
jasbo
