Question about HSM 125.2hs Shredder
HSM 125.2 Shredder all of a sudden will make a loud noise. It will turn on and spin but slowly and make like a thumping noise. Is there anything that I can manually do or do I have to call maintenance
The shredder is well taken care of, always using oil and keeping it clean. Not sure if something jammed it as I already looked in it and found nothing.
4 Suggested Answers
  • 35 Answers
SOURCE: HSM 125.2hs Begins feeding then stops
There are three things that cause this problem.
1. a gear is broken which will cause only one cylinder to rotate.
2. on the non-driven side (opposite side of the gears) there is a electromagnetic sensor that rotates with the shaft. It detects rotation and overload. If this is out of place or damaged it will cause this symptom.
Posted on Feb 24, 2009
  • 45 Answers
SOURCE: hsm 225.2 jerks in & out 2-3cm and wont eat paper!
try oiling the cutters...this helps out with the shredding of paper...also make sure properly mounted on bin, try resetting the shreddar, unplugging it and then plugging back in...check to make sure no paper or anything stuck in shreddar and make sure no broken gears..if this doesn't work and your shreddar is under warranty it would be a good time to call the warranty company
Posted on Apr 16, 2009
  • 41 Answers
SOURCE: Where can I buy gear wheels for a HSM 125.2 paper
cooksmobileshred@bellsouth.net 901-565-8188
Posted on May 10, 2010
My Performa Top Load Heavy duty (PAV1000AWW) has a loud noice when it is spinning. Just changed the belt but still extremely loud when spinning...any suggestions>
Thanks for choosing FixYa and welcome to the site. Anytime you have noise while spending, loud thumps and noises, it can almost always be traced back to the drive motor. This is what allows the washer to spin, drain, and agitate. You need to check this out first and check your spin bearing as well. I would say one or the other is the reason for your noise.
Apr 26, 2011 | Maytag Washing Machines
My washer mad three loud thumps and then would not spin at all. It will pump the water out but will not spin. Do you think it is the belt. Thanks helyn
The belt might have slipped off the pulley. But when you mention that you heard loud thumps before it stopped spinning is a sign that something else might have gone wrong with your machine. With the washer turned off, turn the wash drum by hand and listen for any noises. It should turn quietly without any kind of thumping noises. Also look how the drum turns. It should turn smoothly and not wobble as it turns. If it wobbles or makes thumpiing noises, it means that the support arms are broken.
Reparing the support arms is an expensive repair, unless it is still under warranty, it not worth fixing. Get a few estimates before deciding to repair or replace it.
Feb 08, 2011 | Frigidaire ATF6000ES Front Load Washer
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Turns on and shreds for about half a page, then automatically reverses.
My shredder is jamming. Would oiling it help. I have never did anything with it until now it needs help.
Nov 09, 2009 | HSM 125.2hs Shredder
Tub makes loud thumping noise when spinning
Good morning! It's common to hear a loud thumping noise during spinning because the load (clothes) are not properly place in the tub. Please try to put the load in order & compress it down. best regards.
May 02, 2009 | Washing Machines
Hsm 225.2 jerks in & out 2-3cm and wont eat paper!
Apr 13, 2009 | HSM 225.2hs Shredder
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Hsm 125
Sounds to me like a the main control board is fried. That smell was probably a resistor or a rectifier burning. The fact that you hadn't oiled the shredder in 3 years didn't help, probably put an extreme load on the drive motor. You might be better off, shopping for a new shredder, unless this is a high end industrial strength model.
Sep 05, 2007 | HSM 125.2hs Shredder
HSM 125.2hs Shredder Logo
63 people viewed this question
Top HSM Office Equipment & Supplies Experts
Andrew Taylor
Andrew Taylor
ray gallant
ka4iup
ka4iup
Are you a HSM Office Equipment and Supply Expert? Answer questions, earn points and help others
