Question about Venturer CD2770 CD Shelf System
Venturer 9224 5 disc shelf system
Drawer won't open but motor is working, is something of track
    New Friend:
    Problem Solver:
CD don't get out of my system
Posted on Dec 03, 2014
2 Suggested Answers
chie-chie
  • 98 Answers
SOURCE: Venturer SCD CD 2160 shelf system
you have to replace belt inside the player sometimes this rubber wear out..
Posted on Feb 05, 2008
My bang & olefson cd 50 will not play. hear "spinning" sound when disc inserted.
THE CD50 DOOR MECH IS BELT DRIVEN IF THE BELT IS WORN THE DOOR OPEN/CLOSE SWITCH WHICH IS TRIGGERED BY THE MAIN CAM UNDER THE MECH MAY NOT BE FULLY CLOSED OR THE SWITCH MAY NEED CLEANING,ITS A LEAF SWITCH.THE MOST COMMON REASON FOR THE DISC TO SPIN BUT NOT READING DISC IS DISC MOTOR NOT GETTING UP TO CORRECT SPEED.IT CAN BE REMOVED,DISMANTLED AND LUBRICATED BUT CARE MUST BE TAKEN TO MEASURE THE TURNTABLE HEIGHT,BEST MEASURED FROM THE BASE OF TURNTABLE TO CHASSIS WITH FEELER GAUGE,CAUTION THE MOTOR SHAFT HAS SEVERAL VERY FINE WASHERS INSTALLED DONT LOSE THEM.
May 21, 2014 | Bang and Olufsen Beocenter 9300 Shelf...
Sharp CD-BA2100 cd drawer won't turn or close.
Take the 4 screws out of the top, lift the CD drawer out, disconnect the two wire harnesses, take the top off, lift the 3 disc tray out, then force the drawer open and closed a few times until it slides freely. Put it back together and it may or may not work. Worked for me.
Mar 28, 2013 | Sharp CD-BA2100 CD Shelf System
Gpx stereo cd won't work
The laser pickup head has failed, or the pladder motor that spins the disc is open, or there is no voltage to the motor. Chances are the whole assembly will need to be replaced, but as a rule it is cheaper to replace the stereo.
Jun 23, 2012 | GPX HM3817DT Shelf System
It doesnt recognise cds
There are a few possible causes. 1. Lens on laser pickups dirty. 2. The belt that closes the drawer also lifts the CD assembly to allow disc to spin. If the belt is loose, drawer may close but not be able to lift CD. Listen to mechanism after drawer closes. Do you hear the disc spinning up? or Do you hear a motor trying and then shutting off? You can also remove the case top and visually check these. 3. The spindle height may have slipped. 4. The focus and tracking may have changed with age. 5. The pickup may be bad. And finally the carriage may be stuck and not moving the Pickup(Laser Assembly) to its start position.
Jul 17, 2009 | JVC MX-D401T Shelf System
RCA RS2654
There were 2 problems that I found with my daughter's rs2654, which wouldn't open. The first is that a 2.2 ohm resistor opened up near the IC that drives the motor that opens the drawer, so no voltage to the moter. The second was that the grease in the gears was so stiff that the motor barely turned the larger pulley. Changing the resistor and cleaning up and regreasing the gears fixed it.
Jan 02, 2009 | RCA RS2652 Shelf System
CD Player
WIthout knowing the specific model, I can't be 100% sure, but a number of models in that vintage had a problem with cracked ribbin cables that go to the drawer unit. Replacing the cable usually fixed the problem. What is the specific model number?
Dan
Jul 29, 2008 | Sony CMT-CPX11 CD Shelf System
Feb 05, 2008 | Venturer CD-2160 Shelf System
Disc Drawers will not open
There maybe a CD stuck in the mechanism or it may need to be mechanically reset. Not much you can do except take for repairs.
Jan 05, 2008 | Sharp CD-ES9 CD Shelf System
Electronic repair
the drawer is not seating all the way with the disc, open to make sure nothing is blocking the disc when it slides in.
Oct 08, 2007 | Sony CMT-EX100 CD Shelf System
Venturer CD2770 CD Shelf System Logo
99 people viewed this question
Top Venturer Audio Players & Recorders Experts
Thomas Perkins
Thomas Perkins
Tom Chichester
Are you a Venturer Audio Player and Recorder Expert? Answer questions, earn points and help others
