After turning off my dvd player i have a faint dvd letters across tv and picture is a bit blurry
How do I turn dvd player back to cable tv with out dvd reading faintly across the tv after turning off my dvd player I don't feel the dvd player is off completely because there is a faint green dvd letters across my tv why
SOURCE: moving line through plasma and LCD TV's
This is a very common Ground loop problem. The quick cure is to put a 2 prong to 3 prong adapter on the plugs which effectivly removes the ground from the circuit and stops your lines. Have fixed over a hundred TV's since the 60's that way.
Posted on Oct 04, 2007
  • 129 Answers
SOURCE: scrolling faint diagonal lines
IS NOT CLEAR IF YOU ARE USING CABLE BOX OR THE TV TUNER . BUT IF ITS THE TV TUNER IN USE WHEN THIS HAPPENS , MORE LIKELY TO BE A BAD ANTENNA CABLE CONNECTOR
Posted on May 16, 2008
ensapp
  • 30 Answers
SOURCE: lg 32lcd2d (tv won't turn on)
It is most likely the power supply. If you see domed caps change them using a higher voltage cap. If it's 1000uf at 15vdc put in a 1000uf at 25 or 35 vdc. If this helps let me know.
Posted on Oct 16, 2008
phongnv
  • 56 Answers
SOURCE: vizio p42 very dark screen backlight off
There is no back light in plasma TV, Base on the description, the Z Sustainer board is bad. Replace the board will fix the problem.
Posted on Feb 17, 2009
  • 125 Answers
SOURCE: Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Posted on Mar 14, 2009
I have a Protron LCD 26" TV model#LT26CIPI...The tv was working great turned it off on night and in the morning turned it back on to sound but no picture just a Black screen...when you change channels
Since its a LCD take a flashlight and have the room as dark as possible and with the light look to see if a very very faint image of the picture can be seen or not---many of these sets use a "back light" for the brightness and if that's not on.......
Dec 11, 2012 | Protron PD-DVR100 DVD Recorder
Connecting tevion DVD player to palsonic tv for first time in ages. The picture works, but the sound is only very faint, even if I turn up the sound to the maximum on both devices. How can I fix the s
Those cables are RCA jacks. You need to connect all 3...red white yellow. You dont need 5 like in the video. So on DVD Player connect red to red ...yellow to yellow.....white to white. Connect to audio/video out. Then on TV connect audio/video in or input same way red to red ...and so on.
Oct 06, 2012 | Televison & Video
I have owned an emerson tv for two years now. All of a sudden the picture has become very blurry and white. It is not the cable connection and a DVD is also white and blurry. Even the input channels are...
you must open the back cover of tv, and then things you should do is set "SCREEN" adjustment on the flyback transformer. you must turn it counterclockwise to reduce and decrease the level of screen brightness. turn screen adjustment gradually until the horizontal blanking lines disappear from the screen. and blurred images will be sharp again
Aug 11, 2010 | Emerson EWF2004 20" TV
Blurry Picture
I know these models came out around 2001, and I'm afraid that the problem sounds like it is related to the bulb going bad.
This article outlines how many TVs from around the turn of the century have had similar problems to yours.
I know bulb replacement is an option. You may want to call around to TV repair shops and see what your options are. In the end, though, it may be time to start saving up for a new TV.
Jan 31, 2010 | Hitachi 43UWX10B 43" Rear Projection...
RCA TV. No picture yet has sound.
I unplugged the tv and the cable box and pulled out the battery of controls for 12 hours. When I turn on again, the tv and cable box back to normal.
Jan 24, 2010 | RCA Televison & Video
Insignia 42 LCD TV Blurry Picture. Computer
tuner is going bad use a cable box that has hdmi or component video to bypass the tvx tuner
Jul 02, 2009 | Insignia IS-LCDTV32 32 in. Television
TV makes humming noise, lamp light is blinking, does not turn on
Your color wheel needs to be changed. Mine just did the same thing. I changed mine, and the buzzing sound went away, however now my picture washes out with light or yellow colors. The darks look green and purple also.
Mar 28, 2009 | Samsung HL-R6167W 61" HDTV
Can't get the DVD player to play on new TV
turn dvd off ,unplug cables, turn dvd on, plug cables back in
Mar 11, 2009 | Proscan 32LA30Q Television
TV won't turn on
When I try to turn the tv on, the green light flashes and eventually goes back to red. A very faint picture came across the tv a few times but didn't stay. The tv is only 3.5 years old.
Jul 10, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Televison & Video Logo
10 people viewed this question
Top Televison & Video Experts
Electro Med Services...
