Question about Electrolux Kitchen Ranges
Clean air conditioner filter
How to open to clean air con filter?
    New Friend:
The hand wheel of my new singer 1408 is not working, it is newly bought.
Posted on Feb 11, 2014
What does it mean when the clean filter come I washed fliter
Its sign of you air con filter has been dirty need go clean it .
Aug 07, 2016 | Arctic King 10,000 BTU Slide Casement Air...
How do i open air conditioner to clean filters
A wall unit, split system can be tricky to get. Some filters slip out, some are behind a cover held in by screws, others the complete plastic needs be removed. The filter would be in the section where the air enters the air con.
Other units have the filter behind the return air grill, others a door needs be removed to access the filter rack
May 08, 2015 | Heating & Cooling
Air filter how to clean it
My air con unit has a fine plastic mesh in a frame.
I simply remove it and place it in a sink and soak it through, then I use flowing water to dislodge any dust left, shake and leave to dry before returning it to the air con.
I guess if I were pedantic I should use some type of sterilising cleaning agent, but I've never bothered, and I haven't succumbed to legionnaires disease yet so it's all good.
Mar 13, 2015 | Filter Heating & Cooling
How to clean the air filter
VY commodore smelly air conditioner
Probably a build up of grime, mould, cigarette smoke(if you smoke in the car)_ etc etc. The air intake is under the passenger side. On some models , there is a filter that can be removed and cleaned, you would have to check with your Owners manual or a Dealer. There are cans of air con deodorisers available from Air conditioner parts stores (Actrol, Heatcraft , Airfridge etc) Spray the can into the air inlet of the air con whilst running. It kills anything bad and cleans and sterilises the air con. These cans are about $45 to $50 each, but they work better than unloading a can of Glen 20.
Sep 09, 2013 | Cars & Trucks
Air con is working, but not cooling the air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 05, 2011 | Samsung AS18A6RB Air Conditioner
Show me where the filter is located
dear sir /madam
please know what is type your air-con i mean widow type or split type or Central air conditioning's unit .if your air con is window type air conditioner then remove cover (grill) and find there is air filter if your air con split type of then open its cover there down side of cover there.is filter located
if air con is central cooling unit the find out your filter in duct side i mean air blower side where fresh cool air going to your room .
use this method i hope you will find solution of your problems
thank you
please vote!
Sep 06, 2010 | Heating & Cooling
Why is there water dripping from the air con?
The most probable cause is a clogged drain line.
Also ensure your air filter and the evaporator coils are clean.
Let us know if this helps and good luck.
Feb 24, 2010 | Heating & Cooling
No Mitsubishi Air Con Manual
ok heres the problem. The a/c filter is clogged or the evaporator coil is clogged. These systems have a metering device that measures the amount of air flow over the coil. If this air flow is obstructed the filter light will flash. If the filter in the unit is clean then the coil has some type of obstruction. This will mean having to clean the coil before the light will go off. An a/c tech should be able to clean this for you and it not be a huge cost. They have the chemicals to get the job done fast and clean.
Change your filter first.
Good Luck hope this helped you some
Dave
Jan 12, 2010 | Mitsubishi MS15TN Air Conditioner
Kitchen Ranges Logo
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
