Question about Buffalo Technology Computers & Internet
Hard drive wont connect to computer
Green light comes on, and when you connect it to laptop/computer with USB, it makes a beeping sound. Looking through computer management storage, computer is not recognizing that it is connected at all.
zzptichka
  • 95 Answers
SOURCE: My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
  • 62 Answers
SOURCE: External Hard Drive has stopped being recognized
First thing to do is to try it on another computer to see if its not your windows playing with you.
If that doesn't work its either the USB controller inside your Hard drive box or the hard drive itself.
The only way to figure it out from there is to open the Hard drive case remove the Hard drive and either try it with another usb module that you know works or plug it right in the computer with IDE or Sata interface.
Posted on Jun 01, 2009
  • 16 Answers
SOURCE: Hard Drive not recognized by laptop
The Hard Drive could have come loose from the SATA or PATA connection, or your Hard Drive could have simply died. If it is still under warranty; replace it. If it is out of warranty; open the external casing and check that the HD is connected and / or test the HD in a separate external casing or Desktop that you have. If it is connected and the external casing is working properly (or Desktop is booting properly and can read it), then you have a dead Hard Drive and will have to buy a new one.
Posted on May 03, 2010
shibuda
  • 1812 Answers
SOURCE: My computer is not recognizing that the hard drive
You will uninstall all the usb universal root hub , and to do follow all the steep.
R- click on My com>Properties>Hardware >Device manager>Scrol the mouse down for select usb . Now you will uninstall all the usb and restart the raptop again.
If your problem will same ,change the usb cable for HDD.
Hope it will help you.
Posted on Dec 25, 2010
  • 14 Answers
SOURCE: My External Hard drive is not recognized and makes sound
Have you tried connecting your external to some other computer or OS, will the same problem occur?
Well, in thiscase the MOST effective way is to try some so-called data recovery software to see if you can find some data back. Recommend you have a try of Wondershare Data Recovery. Get the program from its site.
data recovery (for Windows OS)
Mac data recovery (for Mac OS X)
Good luck. I hope that my reply has shed some light on the problem! Remember - Always make Backups of your precious data!
Posted on Jan 13, 2011
How to access my Buffalo HD-PNTU3 external hard drive?
dropping it while turned on is fatal as it usually damages the write heads and/or the platters.
if it hit the floor, changes are it's physically damaged the mechanism.
recovering data from a drive with this damage is not cheap as you will have to send it away to be rebuilt. It's impossible to rebuild it yourself.
Feb 21, 2016 | Buffalo Technology Buffalo MiniStation...
Data Recovery Hard Drive Not Mounting
> no beep, click or error sound occur, but the drive is simply not mounting ...
> . I need the data on it
Too late! The disk-drive has "died". Your data is GONE.
Nov 11, 2013 | Western Digital WD5000BMVV 500GB 5400 RPM...
My buffalo ministation 3.0 external hard drive wont be recognised by my comuter. to be honest i dropped it, but when i plug it into computer green light starts flashing, after a while fashing stops green...
My ministation was doing the same, beeping and flashing green light after a light drop on the floor. Soo... I took my ministation usb drive out of the plastic enclosure and smacked it on the table a few times. Plugged it in and it spun back up!! Now my computer recognizes it and everythings working smooth! I assume something with the drive became jammed and the couple smacks loosened the drive head.. Anyway, if all else fails... beat it!
Nov 05, 2012 | Buffalo Technology Buffalo MiniStation...
The green light on front of my HP computer comes on for a couple seconds and then it goes to red light blinking and beeping try to turn off and back on several times and go right back to blinking red
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 04, 2012 | Computers & Internet
I have the wd elements 1tb portable drive..it gives me a beeping sound and willl not come up on my laptop..i can see it in device manager but the elements will not come up on my computer..the beeping sound...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 18, 2011 | Western Digital Passport WDXML800UE...
I have a Buffalo hard drive 500 gb, it has just stopped working green light comes on and it sounds like it is fireing up but stops light stays green no autoplay through my laptop I have also tried on other...
The power-supply seems OK, since you can hear it spinning, and the lamps are lit.
So, either the USB-to-disk-drive interface has failed, or the disk-drive itself has failed.
Open the enclosure, and remove the disk-drive, and connect it as a "slave" disk-drive in some desktop computer, to see if it works, when you bypass that 'USB' interface.
Jun 08, 2011 | Buffalo Technology DriveStation HD-HC500U2...
My portable hard drive wont connect to my computer. When I plug it in a blue light on the device light up, and it makes a constant beeping sound, but my computer does not register the device. It works on...
hi there,
While the Hard drive is connected to one of the USB ports on your computer.
On your keyboard press and hold the power button and press the letter R.
When the Run box comes up type in devmgmt.msc
Expand the Universal Serial Bus cotnrollers
right click on every root hub and choose uninstall
after that restart the computer
Hope this helps!
May 05, 2011 | Verbatim 96823 320 GB USB Portable (Blue)...
When plugged into USB slot, Beeping annoying sound to begin with, followed by light flashing and Hard drive not being detected. Thanks
This issue is related to the hard drive, Have you dropped the hard drive at any time recently? If so then you may have lost your data. Since the hard drive is makeing a beeping noise then the head has died meaning the hard drive is dead hope this helps.
Apr 08, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Green light wont stay on on memorex traveldrive
The light signals a connection between the hard disk inside the Traveldrive to its case. If it fails that means that the hard disk is dead. The unit has died, junk it and buy a new one, hard disks can't be repaired.
Aug 25, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
Computers & Internet Logo
18 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Ali Reza
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
