Question about Stoves Ovens
Stoves 750 GRF fan and light won't turn off
Just moved into an apartment in NY with a STOVES750 GRF built in oven. Seller did not leave any manuals. Used it for the first time and fan and light will not turn off!
  • 3 Answers
SOURCE: DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Posted on May 30, 2008
  • 250 Answers
SOURCE: I'm looking for an instruction
Let me have an email address for you and I will give it access on my BT Digital Vault for you to down load a copy that I have scanned.
Posted on Feb 09, 2009
  • 38 Answers
SOURCE: how does the q900 works
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Posted on Feb 11, 2009
  • 89 Answers
SOURCE: STOVES 600 oven door wont shut properly
open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
Posted on May 26, 2009
SOURCE: No heat from oven but fan and light works
Timer might be blocked on auto, you need to get it back to a manual setting.
Posted on Oct 18, 2009
STOVE Q 720 GRF DO continuously on OR does not maintain the right temperature and goes off. Could it be the thermistor? Problem in both ovens
If it has a digital display, then it is computer controlled... which means you need a new controller board.
Dec 31, 2014 | Ovens Ovens
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
How to light the pilot or the burner on a built in Tappon gas double oven?
Find the gas valve under the stove, First turn off all gas. Let air out 15 minutes, then turn valve to pilot or light, Then light with bbq lighter, Keep pressing in valve for exactly 1 minute, then turn and leave in ON position
Sep 16, 2009 | Ovens
May 26, 2009 | Ovens
STOVES fan oven - inlet fan on regardless HOB GRILL or OVEN
It is correct. The exhaust fan comes on to exhaust any heat.
The oven fan is for more even baking.
Apr 22, 2009 | Stoves Premier 600EMa Electric Single Oven
How does the q900 works
Feb 11, 2009 | Stoves Premier 720GRa Gas Double Oven
I'm looking for an instruction manual for a Stoves 900 GTF built-in fan assisted main oven. Can you help?
Dec 05, 2008 | Stoves 720EF Electric Double Oven
Open Questions:
Ovens Logo
23 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
