Hoover DYN 9144 D3X
My washing machine has the symbols EO3 on the display . Wot does this mean ?
2 Suggested Answers
  • 6277 Answers
SOURCE: my hoover dyn 8164d washing
Hoover's 'e03' states 'drain timeout'- probably a blocked filter or even jammed drain motor/pump.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 07, 2011
What does Eo3 mean cannot open door
Could be blocked pump, if water is in the machine the door will not open, open the filter and give it a clean, its normally located bottom right hand side of the case....
Oct 02, 2016 | Hoover DYN8163D8X White 600 mm Washer...
Wa250 3-L Komatsu wheeler loader has a call EO3. What the sequence yo the code out?
Re: error code E03 on washing machine
Eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Oct 01, 2015 | Washing Machines
What is eo3
I need the model number to be sure, but, based on when you get it in your cycle, I'd check the drain pump and clean out the trap.
Oct 14, 2014 | Hoover Washing Machines
Candy grand o evo error eo3
Not drained in time allowed - washing machine fails to drain water
·Check that filter is not blocked or obstructed
·Check drain hose is clear of any blockage or obstruction
·Check wiring to drain pump
·Check drain pump is not defective
·Check level sensor or switch
Check wiring to level sensor
Jun 04, 2014 | Candy Washing Machines
Eo3 error message hoover washing machine
Unplug machine for 2 hours to reset the board electronics and re-plugin to load fresh computer code onto board.
Oct 15, 2013 | Hoover Washing Machines
Lock displaying symbol
Haven't done this exact model but usually it means keypad locked (child lock) should be in the manual how to unlock. Usually hold down a couple of buttons for 5sec.( most of the time a faint lock symbol will be written between the buttons on the button panel.)
Sep 23, 2013 | General Electric WCVH6800J Front Load...
My Beko washing machine is displaying C on on the display and will not start.Any Ideas please.
"C on" means that the child lock is on; press the two buttons that are linked to a lock symbol at the same time for 3 sec. ;)
Sep 01, 2010 | Washing Machines
Our whirlpool tub has an EO3 message on its control panel--what does this mean??
If you have the manual, quite often the codes are posted. You could download a manual for your tub from whirlpool websites.
Oct 15, 2009 | Washing Machines
The digital display is showing a KEY symbol flashing, and i can't program a new load. What does this mean?
This is the childproof lock symbol and prevents you from changing a program once it has been selected The symbol flashes if the program is changed during a wash cycle. If the machine is switched off mid cycle with the lock on then it will continue the program as so as the machine is switched back on. To activate the lock press the START button and hold for 4 seconds and the key is displayed. To deactivate the lock press the START button and hold for 4 seconds until the key symbol disappears.
Sep 30, 2009 | Bosch Exxcel WFX 2467 Front Load Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
