My MG7100 pima printer keeps telling me the paper tray needs filling but it does not? every time I go to print this is what happens. It says I need to load paper
Cops
  • 64 Answers
SOURCE: Printing from different trays
this can normaly be solved by going into the printer preferences and then setting the trays manualy in the software. otherwise the printer will automaticaly select the main tray first then move onto the mp tray. sorry if it sounds a bit vague but these options change from printer to printer and have not seen a k850 for a while Hope thyis helps Cops Pete@wedotoners.com
Posted on Oct 08, 2007
  • 461 Answers
SOURCE: My printer c5280 keeps saying please reinsert or lower photo tray
This model appears to have several trays for print media see the manual. Check the default print settings by right-clicking on the printer icon in the Printers and Faxes folder and see that the default is set to what you print most. Also verify all trays are inserted properly and that you have plain paper in the paper tray.
Posted on Jan 17, 2009
SOURCE: Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Posted on Jun 16, 2009
SOURCE: Keeps telling me to load tray 1.
dragon is a moron... cram cheese into the cyan ink cartridge.
Posted on Jul 08, 2009
xptareq2000
  • 1447 Answers
SOURCE: I have a brother MFC-9440cn printer. The printer
When you ready to print your computer.please go to print properties setting paper source default or tray 1 or MP.MP mean multi pass tray.I mean front paper loading tray.
Posted on Jan 14, 2010
No paper in tray light on all time
There is a plastic arm that rests on your paper. As the paper supply decreases, this arm drops lower and lower. When you are out of paper, the other end of the arm trips a photo sensor that tells the printer "you are out of paper." The sensor is either jammed or broken. Pull the tray out and examine the printer for the paper sensor.
Nov 19, 2013 | Dell 1320c Laser Printer
My HP Laserjet 4L has started jamming paper when I try to print more than one page.
Here is some tips to avoid paper jam..
  • If your printer has a paper tray do not fill the tray to capacity. If you're encountering frequent paper jams, reduce the amount of paper you place in the tray each time it is filled.
  • Make sure you or the tray feeding the paper into the printer is aligned properly and the slider used to hold the paper in place in the tray is snug with the paper. Many printers have sliders that allow different types and sizes of paper to be fed into the printer. If the slider is not properly positioned it can cause paper jams.
  • Use standard office paper; folded paper, paper with labels, and specialty paper such as hard bound paper can often cause paper jams. If you're uncertain with what paper you should use with your printer your printer documentation will list the paper compatible with your printer.
  • Do not mix the paper you're feeding into the printer at one time. If you need to change the paper or size of paper being used removed any other paper currently in the printer before inserting the new paper.
  • If your printer uses a slot or tray for the paper make sure to not push the paper too far into the slot or tray.
  • Examine the printer for any previous stuck paper in the printer. Previous paper jams, torn paper, printing labels or other foreign objects in the printer can cause reoccurring printer jams.
**If you need any kind of technical assistance you can contact support cell at here
Feb 26, 2013 | HP LaserJet 4L Printer
Paper jam
Jan 24, 2013 | HP Deskjet 3050A J611G Inkjet Multifunct
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
Canon pixma 3100 keeps saying load paper and won't print
If you have paper in the loading tray and it keeps giving you out of paper message then the sensor by the loading hopper is not working and would need to be replaced.
9 times out of ten though you might want to clean the printer and make sure the hopper is not just jammed this happens when you put too much paper in there at one given time.
thanks
Sep 17, 2009 | Canon PIXMA MX310 All-In-One Printer
Media is not picked up from the media tray
save the document to your desktop or copy and paste into word or notepad..
tell ya printer settings to clean nozzles.
remove paper.
place paper into tray area but not a whole lot....15-20 sheets...
now print...hows that..:-)
Sep 15, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
LaserJet 1200 Stops pulling paper
If the printer works fine for you, but doesn't work properly for someone else I would assume user error. Just make sure that there is plenty of paper in the tray and that it is centered. Also look around for any small peices of paper that might've gotten stuck near the tray, preventing new sheets from getting pulled.
May 06, 2009 | HP LaserJet 1200 Printer
If it is asking for photo paper you should be able to hit ok on the screen and then it should go to the default screen and be ready to print.
Jan 17, 2009 | HP Photosmart C5280 Printer
Printing a document on a pixma ip200
you may need to change the paper source in the printer setup for whatever is printing
Mar 18, 2008 | Canon PIXMA iP2000 InkJet Printer
125 people viewed this question
jasbo
jasbo
