Question about Frigidaire Kenmore Washer Tub to Pump Hose 134455900
Kenmore dishwasher 665.13129K703 is not flushing all water
  • 63 Answers
Most likely problem is food particles or if jars and/or dishes with labels have been washed the scren protecting the scavenger water pump in the bottom of the dishwasher is blocked. Carefully feel around the screen for the blockage. I say carefully because it is a place to find broken glass also.
Posted on Jan 14, 2015
Kenmore Quiet Guard is clogged on the bottom. Leaking water.
take out the bottom rack, pop out the center. use a snake on the drain. if not aviable us a wirer coat hanger. the water should go down. to top it off ad some draino or something like that. but rises your dishes before you put it in the dishwasher. remember a dishwasher is not a garbage disposal. run the dishwasher again i wish nothing in it. that will flush out the drain. then your good.
Jan 02, 2013 | Dishwashers
Why does the heating element in my Kenmore elite look like it has a white film on it?
hard water. test water hardness, clean out with 8oz of CLR. and run affresh once a month for maint. ALWAYS RUN A FLUSH CYCLE AFTER ANY CHEMICAL
Oct 02, 2012 | Kenmore Elite Stainless Steel 24" BuiltIn...
Recently there's been a white coating on dishes. Has to be scrubbed off manually or soaked in a vinegar/water solution. I flushed out the rotating arms to be sure water flows thru & it does. Checked...
use any brand of dishwasher cleaner from a local store and run your dishwasher with it.I would also recommend that a calcium lime and scale remover be ran through your dishwasher to clean it out.
this may have to be done a couple of times.
Jan 16, 2011 | Kenmore Dishwashers
Loud noise starts as soon as water starts coming into dishwasher. Stops when water in or water draining. What could it be?
This hammering is usually from restrictions in the water line or inside the valve on the machine itself.
Try taking the water line off of the machine(with the water supply turned off) then disconnect the line from the dishwasher and flush water into a bucket from this line until it runs clean. Reconnect, if it still makes the noise you will need to replace the inlet valve on the dishwasher. Let me know if this was helpful or if you have questions please.
Thank you
Jun 14, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
Not draining at all. water collected at bottom of unit. tried "cancel/drain" numerous times and water remains at bottom of unit.
Possible blocked waste pipes or cycle pipes. but some specialist de-greaser and let it soak in dishwasher over nite - put dishwasher on in morning, repeat until its flushed.
Feb 16, 2010 | Kenmore Dishwashers
I have a kenmore dishwasher and the dishes, especially on the top rack have debris stuck to them after it has run. What should I try?
Remove top spray arm and flush through the holes with running water. Then re-attatch.
It's usually bits of food debris that block the holes.
Aug 04, 2009 | Dishwashers
Kenmore Ultrawash Quiet Guard 5 making buzzing/grinding noise
I have a very similar dishwasher, with a very similar problem. I fixed it by removing debris from the water evacuator pump located towards the front of the bottom of the machine (the last motor before the drain hose. In my case, grape stems had clogged it up. Once emptied, it purrs once again. NOTE: don't disassemble the motor, just flush it out, there is an o-ring gasket that is a bear to re-install.
Jun 22, 2009 | Kenmore 24 in. 15689 Built-in Dishwasher
Kenmore portable dishwasher not working
THERE IS A PLASTIC COVER GRATE IN THE BOTTOM OF THE DISHWASHER TAKES A 1/4 INCH NUT DRIVER TO REMOVE IT, TAKE IT OFF CLEAN OT THE DEBRIS AND FLUSH WITH A BUCKET OF WATER, THIS IS SUPPOSED TO BE THE FILTER, IF ANYTHING IS IN THERE YOU WOULD BE ABLE TO SEE IT, I HAVE FOUND STRAWS AND KNIVES IN SOME DISHWASHERS, HOW THEY GET IN THER IS A MISTORY BUT THEY DO
May 29, 2009 | Kenmore 17252 Free-standing Dishwasher
No water supply
There are a few checks. Try the #1 first and then proceed to the next one til you get water. Here are a few checks:
  1. Turn off the supply and disconnect the supply line to the dishwasher, turn the water on to flush the line and to check for flow
  2. If you have water to to the supply line, your problem is the water solenoid. Replace the water solenoid.
  3. Turn off the supply, and disconnect the supply line at the shut off, turn the water on to check for flow.
  4. Shut the water off to the house, disassemblehe shut off, clean debris out of shut off. It may need to be flushed. I recommend using a hose to direct the flow into a 5 gallon bucket while someone cycles the water supply.
  5. Replacement of shut off is next.
Please rate this solution.
Aug 03, 2008 | Kenmore 15129 Built-in Dishwasher
Frigidaire Kenmore Washer Tub to Pump Hose 134455900 Logo
55 people viewed this question
Top Kenmore Vehicle Parts & Accessories Experts
Tom Chichester
Jim Rus
Jim Rus
Matt
Are you a Kenmore Vehicle Part and Accessory Expert? Answer questions, earn points and help others
