Question about Wintec Industries FileMate Light 7 Touchscreen Internet Entertainment Tablet with Enhanced Resistive Touch Tec
Filemate clear reset system to factory settings
Had to do factory reset, now unable to download apps from google playstore like youtube etc, any help?
I suggest that you troubleshoot first, instead of a hard reset. Factory reset is within settings.
If any google app won't download nor install, it's probably because your google services are not updated or is corrupted. Try the next steps before factory reset.
1. Go to settings, scroll down to app.
2. From here search for PlayStore and tap it.
3. Tap Clear Cache and Clear data.
4. Go Back.
5. Search now for Google services, this one is not under the download tab, which you can notice at the top of the screen, instead got to All and scroll down until you find it.
6. Tap Clear Cache and Clear data if available.
7. Reboot phone or tablet.
Most of the time this procedure do work, some people also opt to remove the google account and sign in after the reboot.
After the boot, open the PlayStore, accept the agreement and try to download anything from the PlayStore that is compatible with your tablet. Also, just to be sure, go to settings, security, look for Unknown Sources and enable it. This feature allow you to install any apk file that is not from the PlayStore.
Mar 07, 2015 | Tablets & eReaders
Want to erase password and start over
n order to reset to factory settings, please follow these instructions :
- Power off machine.
- Hold down + first and then POWER for about 10 seconds, release both buttons once Kurio screen loads .
- When you get the open Android picture, press + to enter menu, use - to move down to "wipe data / factory reset" and press POWER again to choose.
- Next press - to choose "YES" and press POWER to start reset.
- Check for yellow text Formatting /data, formatting cache, Data wipe complete.
- Choose reboot system now and press POWER to complete process.
NOTE: This will erase data from your Kurio's internal storage such as Accounts, System settings and Downloaded apps. But music, pictures, and other user data won't be erased. Check "Erase SD card" if you want to clear all the data of the system.
It is also possible to reset only the Kurio Interface: Go to Parental area > Tablet Setup> Press "Reset the Interface to Factory Default Settings".
Once this has been done you will need to set the device up and perform all the updates, instructions for this are on this page.
Mar 04, 2015 | Kurio 7S Tablet
How do I reset my digital2 8" tablet
Depends on the model number.
I found this.
" Click "Settings" ? "Backup & Reset" ? "Factory data reset" to clear all user setting and recover the system to the default status.
Please kindly be noted that some models (like D2-711) may require extra step as to select reboot system now.
(Note: All installed applications and user personal data will be erased (emails, contacts...etc.). Data saved in the internal storage like photos, music files and others will not be erased.) Make sure to back up all your files first."
Dec 19, 2014 | Digital2 Tablets & eReaders
There are no instructions on how to reset my grandsons kurio7s tablet
check out http://www.kurioworld.com/k/us/parents/support/7/gettingstarted
Kurio7s
In order to reset to factory settings, please follow these instructions :
Please feel free to contact Kurio Technical Support on our support page.
Oct 22, 2014 | Tablets & eReaders
Reset premium 8 se tablet
I used a USB charger and plugged into a laptop. Once the device was recognized it unlocked.
Jan 24, 2014 | Wintec Industries FileMate Light 7...
The touch screen on my filemate clear is not working
Have you tried to factory reset it? That could make it reconfigure the touch part of the devise other that that i don't know. If that works please let me know
Apr 30, 2013 | Tablets & eReaders
Reset a kindle to factory settings
Two step process, first step we will Deregister your Amazon account and then we will reset the device.
Step 1: Status Bar More + select Account - Deregister
Step 2: Status Bar More + Select Device - Reset to Factory Defaults
Mar 23, 2013 | Amazon Kindle Fire HD
Reset system to factory settings
here is the solution for identity korean tab
all you need is SD card..512 and up..
format SD card in FAT 32
here is the flash files
extract this file and put in sd card
inset the SD card and power on your tablet
PUSH the reset button beside the usb
you will not see it flashing..
wait till astro boy or android boy pop up...
then erase the file at put this file again in SD card
you will see Korean character
do not touch anything..just wait for 5 minutes then it will reboot once more.
done.........your tab is working again.....rolleyes.gifrolleyes.gifbiggrin.gif
May 15, 2012 | Wintec Industries FileMate Light 7...
How do i unlock my filemate identity tablet?
I used a USB charger and plugged it into a laptop. Once the device was recognized it unlocked.
Apr 26, 2012 | Wintec Industries FileMate Light 7...
Wintec Industries FileMate Light 7 Touchscreen Internet Entertainment Tablet with Enhanced Resistive Touch Tec Logo
47 people viewed this question
Top Wintec Industries Tablets & eReaders Experts
Are you a Wintec Industries Tablet and eReader Expert? Answer questions, earn points and help others
