Question about Miele Vacuums
The power cord will not stay out, keeps retracting
2 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Electrolux Lux 7000 retractable power cord
The trim pieces along the sides just pull off seperating the two housings. The back portion where the retract drum is is held by two plastic tangs on top inside. use a screwdriver to pry the ring down to dislodge the tangs. the bottom part will lift off. remove the front part using two screws just below the hinge. the retract has a long coil spring wound around a free spinning hub. there are two "tangs" inside that engage a ratchet-pawl assembly. you'll need to rotate the drum to rewind the spring onto its hub.
Posted on Aug 20, 2007
Bissell momentum canister vacuum retractable electrical cord not retracting
Either the cord inside is caught on something or the retraction spring is broken.
Try to pull it out further, if you can feel any spring-back then most likely the cord is caught, maybe on itself.
Either way, the canister will probably have to be disassembled to fix the problem.
Sep 17, 2016 | Bissell Vacuums
360 manual
With all that's involved in replacing the cord and potential cord reel damage, it's more cost effective to just have the entire cord reel, complete with new cord, replaced. Less time consuming thus less costly to you. Hope it helps!
May 26, 2014 | Electrolux Lux 7000 Bagged Canister Vacuum
The power cord does not retract or rewind when the button is pushed. How can I repair this?
Sometimes you can help get the springs working again, by gently pulling the cord out a little further and then let it slowly in while pushing the cord retract button.
Nov 08, 2012 | Kenmore 25512/ 25513 Progressive Canister...
I have a Kenmore Vacuum cleaner 116.24212. The retractable electric cord won't retract. How can I fix it?
The retraction mechanizm is likely jammed. Mostly likely the cord has jumped it's groove in the retraction wheel/hub. If you are good with tools there is a 70% chance you can get it to work again with a basic DCR operation. Most mechanical problems can be solved using this simple rule: Dissassemble Clean and Reassemble.
CAUTION: The retract mech has a powerful spring inside, avoid exposing. Most retract mech units are rivoted closed so consumers won't poke thier eye out.
CAUTION: UNPLUG THE UNIT
Open the unit from the bottom and the top lid of the canister should come off.
The retract mech should be obvious as it is where the cord comes into the unit.
Look for the cord being bound by iteslf either on top or underneath (lie two cordes in one groove)
Remove any binding.
If you see no debris or obsticals for the cord to retract (where it is getting stuck)
Your spring could have sprung!
Do you feel and retract at all?
Can you locate the releae mechagnism?
Does the Release button seem to function? When Pressed it should take pressure off of the cord hub.
The retract mech may need replaced. Overall the cost will be about $60 for parts.
Feb 12, 2011 | Vacuums
Eletrolux lux7000 manu and how to retract the power cord?
For the user's/owner's manual, go to the below link, click on the arrow below where it says "Older Models", click on Lux 7000, click on "download". If you want a service manual, they are only available to Aerus Electrolux stores.
For retracting the cord, try tipping vacuum up on it's back end and gently pulling and releasing cord. This will often cause it to retract. If not, keep in mind that the canister portion of this vacuum has a 7 year warranty on it, so depending on when you purchased it, the cordwinder may still be covered. The warranty does not cover normal wear and tear, or abuse. There are other things that will void the warranty.
Nov 26, 2010 | Electrolux Lux 7000 Bagged Canister Vacuum
The automatic cable rewind on my Morphy Richards pod vacuum cleaner keeps retracting. I'd rather it didn't work at all than be constantly pulling out the cord. Is there any way in to fix it or disable it?
Hi Not really. It means that the cord has been pulled roughly when its been plugged in and the retracter is getting weaker to hold the cord that has been pulled out. Generally though wipe the entire cord from the end of the machine with a dry cloth and some furniture polish. This will clean the cord and add some resistance to the retractor that could minimise the cord flowing back into the vacuum.
Jun 19, 2009 | Miele S251i Plus Bagged Canister Vacuum
Electrolux EL 7001 Oxygen 3 power cord continually retracts
The button has two parts - the inner part (button) and the outer part (surrounds the button). The press the outer part to deactivate (pop out!) the inner part.
It took me a while to figure this thing out, but I was glad the vacuum wasn't broken.
May 02, 2009 | Electrolux EL7055A Bagless Canister Vacuum
Cord will not remain OUT..keeps slip-sliding back in
The return is stuck on your cord retractor. Take the machine apart untill you can see the retractor, then there is a button or wire that retracts the cord. If it is stuck in the down possition simply reset it, if it is broke you must replace the complete cord retractor.
Apr 11, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Vacuums Logo
14 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
