Question about LG LFC25760TT Titanium Bottom Freezer French Door Refrigerator
Digital display reads off and fridge is not cold
There is a pinging alarm sound every few minutes. Sometimes the digital reading shows the temp. And then it reads (off). It goes on again.
HVACRH20
  • 237 Answers
SOURCE: Touch Temp Controls
If the touch control doesn't respond then it's most likely bad. They don't normally act up, they either work or they don't.
Posted on Jan 06, 2007
fridgetech
  • 473 Answers
SOURCE: Lg bottom freezer refrigerator
Some LG's are designed to show an error code when it detects a problem instead of a dianostic mode like in some other brands. Look for a tech sheet on the unit, may be behind the bottom grill under the fridge. This will tell you what the error code means. They will detect things like the evaporator motor not working etc. Hope this helps.
Posted on Oct 06, 2007
huuum
  • 750 Answers
SOURCE: digital display on LG fridge
Hello sewing6
Welcome,
You said,
digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigerator isn't cold at all
Try turning the fridge and the freezer off at the controls.
Then turning off the breaker for the fridge for 5 minutes .
then turn the breaker back on and restart the fridge and freezer!
This should reset the system and solve your problem.
let me know how it goes.
Thank You,
Huuum
Please remember to leave a rating! Hopefully a "solved "one.
Posted on Oct 13, 2008
SOURCE: Fridge doesnt work, freezer works
You need to change the freezer fan motor. FF means problem with the Freezer Fan.
Posted on Oct 19, 2009
  • 884 Answers
SOURCE: Lg premium EZ digital. Digital display for fridge
Sounds like contamination inside the controller. Unfortunately this usually means replacing the controller.
Posted on Apr 21, 2012
Shows code upside down f and a 3
Take a look at these codes and see if any look similar.
Sometimes the digital read-out looks different from printed type.
Down on the page there is a link to explore older codes Samsung Washing Machine Errors eHow
Dec 18, 2015 | Samsung WF419AAW Front Load Washer
Ge fridge controls not working
try unplugging it for a few minutes then plug back in see what happens
Feb 23, 2015 | GE Refrigerators
Temp display reads 92 (hi temp) but the interior temp is 0.
No. Sounds like the intern temp sensor is bad, missing, or not connected. 92 is probably the max reading it can display. The unit will probably operate continuously, be much to cold, and cost a ton to operate. I assume you bought this from Sears. Call them to replace the freezer. Should be no problem.
Oct 24, 2012 | Kenmore 20.6 cu. ft. Upright Freezer 2809
My refregirator temperature sometimes warms up 10 to 15 degrees higher when i open its doors to load it up with items and takes a long time to cool back down.
If your reading the display temp , your reading what the thermistors are telling the control board . NOT the actual temp inside . After closing the door , from the food that was already cold in the fridge , the coldness will keep the inside temp , the same temp as when you opened the door . The thermistors themselves will detect the warmness and send it to the board . A good way to try to put this acrsoo , is to put a thermometer between , say , 2 packages of salads . Wait a little while and open the door . Watch the display temp , then read the thermometer between the packages . The thermometer will stay the same , due to the coldness of the packages not changing . When you put food in the ref , the surrounding food will give off some of the coldness to the freshly installed food , thereby makeing it cold faster . After a while , this coldness will return to the thermistors and the display will start to drop in temp . Hard for me to put into words , except for , the temp reading will actaully be the same as the actual temp display , only when you FIRST open the door .
Sep 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Water dispenser line keeps freezing
no idea.probably need to contact the technician of the manufacturer's firm.
Apr 10, 2009 | Kenmore Refrigerators
Digital display on LG fridge just keeps cycling options. Showed "ER" error. Any ideas on how to get it to stop? The freezer is still cold but the refrigertor isn't cold at all
Hello sewing6
Welcome,
You said,
Thank You,
Huuum
Oct 12, 2008 | LG Refrigerators
Whirlpool fridge freezer (american style)
you have a bad control or bad sensor
May 11, 2008 | Freezers
GE Profile fresh food getting TOO cold
Faulty air damper is the usual cause , or possible sensor fault
Sep 14, 2007 | GE PSS25NGM Side by Side Refrigerator
Side by side fridge freezer
Based on your weird display issues I'd lean toward the control board problem. At least that can be "one" of a couple problems...
Feb 01, 2007 | Samsung RS2578BB Side by Side Refrigerator
LG LFC25760TT Titanium Bottom Freezer French Door Refrigerator Logo
13 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
