Question about Nintendo GameCube Console
Fan not working
I think the fan in my gamecube quit working because i get an error has occured. please turn off gamecube and consult nintendo gamecube manual ( something like that) My daughter noticed the gamecube was very warm so she got a small fan and put right next to the vent that has power and reset button side. It seems to have fixed the problem for the most part. How do i take this thing apart when it is riveted together?  I need to get that fan working again.
    Problem Solver:
  • 19 Answers
Some of the early Nintendo GameCube Systems released were prone to overheating, especially if played or left on on for a long period of time. If the problem is merely the cooler fan being congested with dust or pet hair, a simple cleaning will suffice. But if a clean fan and open air does not fix the problem, then there is heat damage done to the chips and you should replace the board (cheaper than replacing individual chips). You can pick up the Gamecube Motherboard CPU and Heatsink (analog type as well as the double digital & analog output) for around $15 to $20 dollars. They are pretty easy to install with just a couple screwdrivers and the bit used to open the Gamcube case. You can find them at nesrepairshop.com.
The best way to avoid overheating in your Gamecube in the first place is to make sure that your system is placed in the open where the vents on the side are not blocked from receiving free air flow. You should also check these vents periodically to make sure they are not full of dust or other blockage. If there is dust in the vents, you can use a vacuum cleaner with small corner or upholstery attachment to pull it out. But "never" us canned or compressed air as that will inevitably cause problems with circuitry, moving parts or the laser. I also use the additional little Dream Gear Digi fans that easily attach to the side to add additional cooling. These work great.
Fan not working - 09d88c56-2167-4f57-9af3-bf36383b05c5.jpg NES Repair Shop NES Parts NES Games NES Sales Nintendo Service
Posted on Sep 18, 2014
  • 47 Answers
The game cube is not riveted.  Nintendo came up with a special screw that has a special bit to open the cube.  They did this in an attempt to keep only authorized service techs working on them.
http://cgi.ebay.com/_W0QQitemZ300160734198QQcmdZViewItem
They are really cheap :-)
And the fan may not be bad, just might be all dusty.  Don't blow compressed air in it until it is apart though, you do not want Dust on the laser.
Hope this helps
Posted on Oct 27, 2007
I plug it in and only the fan will turn on
Something might be wrong with your Nintendo Gamecube as a whole. I'm not totally sure. I've heard of Gamecubes working, but the fan is broken, but the other way around, that's a bit strange. If you can post some more information, can you tell me if the Gamecube actually turns on to the point where it says "No Disc", or it just doesn't even show a picture when you hit the power button.
Jul 01, 2011 | Nintendo GameCube Console
My gamecube starts up disc spins fan comes on then before game starts it says an error has occured please switch off console and refer to manual? Is it beyond repair or can it be fixed it was fine one...
Well it might mean that either the disc's are dirty or scratched at a point were the console had troubles reading them or if it works fine on a different system it means that there is an internal issue with your console.
May 14, 2011 | Nintendo GameCube Console
The power cord was pulled out while the nintendo gamecube was loading up. now it says" an error has occurred turn the power off and check the nintendo gamecube instruction booklet for further...
I think that the ac adapter when it was pulled might of damaged the gamecube to some excent
so now it has a hardware issue that needs to be fixed then.
Feb 19, 2011 | Nintendo GameCube Console
When i turn on my gamecube it says an error has occurred and to shut it off and check the instruction booklet for further instructions
  • An Error has occurred:
    If you are getting the specific message, "An error has occurred. Turn the Power Off and check the Nintendo GameCube Instruction Booklet for further instructions." This means there may be an internal problem with the system.
    1. Check Individual Game Disc problems or Multiple Game Disc problems (depending upon how many games exhibit the problem) to see if the cause of the message is a dirty or damaged disc.
    2. If the disc appears fine or works properly in another system, this means there is an internal problem with the system. A repair will need to be set up. Please use our convenient repair options.
  • Nov 01, 2010 | Nintendo GameCube Console
    My gamecube freezes in the middle of a game and says an error has occured, it tells me to check the gamecube manual but i don't have one! PLEASE HELP!
  • Aug 03, 2010 | Nintendo GameCube Console
    Gamecube cooling fan dead and resets after 3 seconds.
    well, replace the fan, for a conventional computer fan.
    Jul 30, 2010 | Nintendo GameCube Console
    My Gamecube won't work right.
    there is to much electrcity in the game console let the gamecube rest for a couple of days
    Feb 28, 2009 | Nintendo GameCube Console
    Nintendo GameCube Console Logo
    175 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
