Question about Samsung Televison & Video
My samsung flat tv model no - CS-29Z45MH is not switching on. a red light blinks . it remains for 5 seconds.
Blinking red light contionus
  • 1694 Answers
SOURCE: No picture or sound - Power Save light blinks red 5 times - nothing on the screen
Best first step = change lamp
Posted on Oct 24, 2007
SOURCE: Red power button & "lamp" indicator blinks
Having similar issue with my PT-44LCX65. Lamp blew and replaced it (last month), never figured out how to reset timer. Now red indicator light blinks once every 5 seconds and after about 4 minutes TV goes black.... Any ideas?
Posted on Jan 12, 2008
  • 59 Answers
SOURCE: PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Posted on Feb 05, 2008
SOURCE: flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Posted on Mar 19, 2009
asnowman
  • 788 Answers
SOURCE: TV won't turn on
If the led is blinking one time there is a problem in the 140 volt circuit. Most likely a shorted Horizontal Output Transistor or a bad flyback transformer.
I would recommend that you contact a local servicer in your area and see if they can come to your house and diagnose the problem and give you an esimate for the repair. This can be tricky to diagnose and the potential for electrical shock is very high. So I would be careful if you wish to repair it yourself.
I would guess that you should be able to get a servicer to your home and repair the set for somewhere between $350.00 - $450.00 depending on the parts that are needed and the area in which you live.
I hope that this helps you with this issue. If you have any further questions, please post and I will try to help you as much as I can.
Thanks for using FixYa
asnowman
Posted on Oct 25, 2009
Sharp tv model lc-32le340 fail to start red light remain blink.
You have verified that the power supply has failed.
Jun 17, 2016 | Sharp Televison & Video
Turns on, but 30 seconds later screen dims and then about 30 seconds after that TV turns off and red light blinks 6 times. What's wrong?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 31, 2016 | Televison & Video
How do i fix a plasma Samsung tv
Tony, need some info for help like model number, age of set, can u unplug for 10 min. then turn back on, and since u have taken back off what have u tested or looked at?
May 04, 2015 | Samsung Televison & Video
50 Samsung plasma turns on got sound fuzz picture
Go in the service manual , find it on the internet and find what they say about the light blinking 5 times. Best of Luck! Serge Lavallee.
Oct 14, 2014 | Samsung 50 in. Plasma TV
I have a samsung 42 inch plasama ty model spp4231 when i try trunin it on the red light comes on it blinks 5 times them truns offWhat's your problem?
Hi the blinking light is a code. The service manual for this TV will have a description of the code. do a google search for the service manual and download it.
you can get parts for this tv at www.interliquidparts.com
Feb 24, 2012 | Samsung SPP4231 42 in. EDTV-Ready Plasma...
When I turn on my HL-T5687S, the screen remains black and there are 3 dots on the lower right hand side of the panel?
My TV is (same model is doing the same thing). The manual shows that the 3 blinking lights indicate "LED may be defective. Please contact a certified technician."
Note: When I power my TV off (unplug) and back on, the TV's left indicator light is solid for less than a second ("Stadby state") then the right light blinks ("The picture will automatically appear in about 15 seconds") for about 15 seconds. This pattern is repeated numerous times (I think it was 5 times). I believe the TV must be failing some power-on test. Aftere failing 5 times it gives LED may be defective indication.
Nov 09, 2010 | Samsung HL-T5687S Television
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
When I turn on the unit I get a green light, but after about 5 seconds it switches to red blinking and I do not get a screen
What is the model of TV?
The Red blinking light is a Protection Error Code. Your Tv needs repair. Most common is the power or Main Unit / Logic Board.
Post your model and how many times the light blinks. Also try unplugging for about 20 min and see if it will turn on.
Some models you get lucky and its a common problum which makes for an easier diagnosis.
Check
RNS-Systems.com
for general pricing on LCD and Plasma TV parts.
Oct 14, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Dec 26, 2007 | Panasonic PT-50LC13 50" Rear Projection...
Televison & Video Logo
19 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
