Question about HEWLETT-PACKARD Hewlett Packard HP 400VA UPS and Surge Protection PS445AAABA UPS System
Been shut off for some time and now will not turn on
Load disc, unit tries to load & play, unit shuts off. Turn power on to set time,etc,machine shuts off.
Laser pickup unit fault. The unit alongwith its flat connecting cable should be replaced. Contact any service technician. Electro help
Feb 23, 2015 | Samsung DVD-V2500 DVD Player
1999 Chevy Blazer. When ignition is turned off none of the accessories stay on anymore.
GM has the RAP system, Retained Accessory Power, locate a wiring diagram, believe there is a relay...
Oct 28, 2014 | 1999 Chevrolet Blazer
My rca 52" tv was working this morning than shut
Replace the Deflection board. You can get the replacement deflection board from www.tvrepairworld.com
Nov 08, 2010 | RCA D52W19 52" Rear Projection Television
Nokia 95 8GB is dead
man check it with a new battery or it may b posible that ur fone s/w is crrupet which need to reinstall by a expert .
Dec 25, 2009 | Cell Phones
My Air Conditioner does not get cold after I turned it off and turned it back on. I have now turned the themostat off about 20 mins ago
Air conditioners need a few mins to stabilize (the fluid in the lines) after they are shut off in the middle of operation. The comperssor will normally time out for several mins after it shuts off (or you shut it ofF) preventing it from coming back on within that time. So if you turn it off, and then right back on, you can expect warm air for several mins untill it times out.
Jun 17, 2009 | Honeywell Electronic Programmable...
It will not automatically turn off when running, the knob does not turn while running.
Miss Stephanie you must replace the timer.
If you have a timed dry setting. Run timed dry. If it does not shut off timer is bad.
If it does shut off you have a sensor problem.
Apr 14, 2009 | Kenmore Dryers
98 Saturn SL1 Intermittent Wipers stay on full
no this is not an expensive problem. you just need the wiper relay switch.
Dec 14, 2008 | 1999 Saturn SL
Headlights stay on when car is shut off & keys out of ignition
Replace the ignition switch - not working properly.
Aug 23, 2017 | 1998 Chevrolet Malibu
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
HEWLETT-PACKARD Hewlett Packard HP 400VA UPS and Surge Protection PS445AAABA UPS System Logo
49 people viewed this question
Top HEWLETT-PACKARD Computers & Internet Experts
Michael Vincent Cruz
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
