Question about Dometic Rooftop RV Air Conditioner
New 5 button thermostat when plugged in EE on screen
    Genius:
  • Dometic Master
  • 1,363 Answers
Not communicating with relay module and t-stat.
Posted on Aug 24, 2015
My Toyo Laser 30 has an error code EE 5 and I can't find any info on that particular code. Help?
Call manufacturer or Installer - Direct Vent Furnaces are not a DIY service. Carbon Monoxide is deadly and can easily be emitted if there is something wrong with the heater. Get professional help before anything further is done, as it needs a full inspection for your safety.
Apr 14, 2014 | Rinnai Toyostove Direct Vent Heater: Laser...
Repair of room air conditioner /window unit
You need to check the main breakers in the breaker panel......
Sep 01, 2008 | Heating & Cooling
Getting an "EE" and it
Check this against your code, but iff EE is flashing you may have an internal electrical fault that needs to be checked out by a repair person.
  1. Frigidaire
  2. GE
  3. Panasonic
  4. Sharp
  5. Whirlpool
Sharp commercial grade microwave codes....
EE Mode Reason Action Required EE 1, EE 2 Magnetron failure
Call for service*
EE 3 Both magnetrons failed Call for service. EE 4 R-23GT, R-24GT and R-25JT only
Voltage too high Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 208V to 230V. If problem is not corrected, call an electrician. EE 5 R-23GT, R-24GT and R-25JT only
Voltage too low Follow instructions on page 5 of Operation Manual under VOLTAGE SELECT to change from 230V to 208V. If problem is not corrected, call an electrician. EE 6, EE10, EE16 Thermistors failure Call for service. EE 7 Exhaust air temperature too high
Check that nothing is blocking air intake openings on oven back or that oven exterior is very hot. Correct. Wait a few minutes and try again. If problem persists, call for service.
EE 8 Circuit failure Call for service. EE 9 Maximum time is exceeded
Check page 11 in the Operation Manual. Touch STOP/CLEAR pad, and reprogram correctly.
EE 0 Fan lock error Call for service. EE17 Magnetron temperature too high
Touch STOP/CLEAR pad. Wait a few minutes and try again. If problem persists, call for service.
* EE 1 and EE 2: Can continue to use oven before service; however, check food carefully as additional cooking time will be needed.
Any time the EE is flashing, the servicer should be called. When EE is not flashing, check the reason and correct. Service is not necessary.
Aug 20, 2011 | Microwave Ovens
TI-84 Plus Silver Edition. When dividing negative powers of ten by other negative powers of 10 the calculator it just adds the the negative powers together. How do i fix this? An example: 5*10^-10 /...
To enter an exponent, positive or negative, use the EE (Enter Exponent) key (the shifted function of the , key just above the 7 key). Do 5 2ND [EE] (-) 1 0 / 5 2ND [EE] (-) 1 0 ENTER and you'll see 1.
What I think you're doing (I can't be sure without seeing your keystrokes) is calculating
5*10^-10/5*10^-10 which is interpreted as (5*10^-10/5)*10^-10, which indeed is 10^-20.
Oct 16, 2010 | Texas Instruments TI-84 Plus Silver...
How do you reset a honeywell th8110u1003 thermostat honeywell 800 # will not tell me but he said it needed to be reset because off ee code on screen
http://www.pexsupply.com/Honeywell-TH8110U1003-VisionPro-Thermostat-1-Heat-1-Cool-3909000-p YOU MAY FIND THE ANSWER HERE BUT IF NOT YOU CAN FIND IT RESET BUTTON IN THE (FURNACE?) UNIT. THE REASON HONEYWELL WILL NOT GIVE THE INFORMATION IS BECAUSE THIS CONDITION USUALLY MEANS THERE IS A PROBLEM IN THE SYSTEM AND GAS IS NOTHING TO FOOL AROUND WITH. FYI HAVE YOUR IGNITER CHECKED OUT.
Mar 05, 2010 | Honeywell Programmable Thermostat Heater
There appears to be a problem with the thermostat/control panel. It won't turn on/off with out removing power. Once turned on, cannot adjust temp or mode or anything.
What type of Thermostat is this? If it is a Comfort Control Center, four or five button, then turn off the thermostat, hold down the mode and zone buttons at the same time and turn the tstat back on. When EE appears on the screen, then release the button and see if it begins to work. If not, then we need to check the control unit in the AC. Hopefully it is just a simple reset.
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
EE button ("enter exponent" button) Retuns Wrong Value
I dont think you got a lemon.
You acn always enter the powers of 10 as 10, [y^x], but is is less efficient than the EE key
This EE representation is a shortcut.
If you want 10 to the 5th power you just enter [2nd] [EE] 5 and the calculator displays 100000. Of course if you need any other number multiplying the power of ten you enter the following e.g. 2.677[x][2nd][EE]5.
You will not get any error with a positive exponent. But if your exponent is negative you should use the change signe key to the left of ENTER and symbolized by (-)
To avoid all errors I would use parentheses to enclose my exponent.
Here is how to explain the seemingly erroneous result
10 [EE] 5 ) (-) is interpreted by your calculator as 10x(10^(-5)) which evaluates correctly to 0.0001 because [EE] by itself stands for 10^ .
Hope it clarifies this point for you.
By the way some new calculators (Casio) don't have this EE key. Instead you find a key labeled x10^X .
Hope it helps
Mar 12, 2009 | Texas Instruments TI-30XA Calculator
Scientific notation
You have to use the EE button right next to the parenthesis and the sigma plus button. So 1.7 EE and then your exponenet. If it is a negative exponent you need to hit the negative button before you type in the number.
Mar 24, 2008 | Texas Instruments TI-30XA Calculator
Ee 5 code on 24GT...
Take a look at this website, its says your voltage is too low..... http://www.applianceaid.com/micro_faultcodes.html#Sharp
Jul 12, 2007 | Sharp R-24GT 1800 Watts Microwave Oven
Dometic Rooftop RV Air Conditioner Logo
66 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
