Question about Emerson Lc320em1 TV
Need to chang the picture size - Emerson Lc320em1 TV
Need to change the size of the TV picture
Hi David,
There is key P Size on the remote control. Please use it and select the size of picture you need.
Jul 01, 2015 | Televison & Video
Need change picture size dont have manual
Hi LaWanda,
You do'nt need manual for this. Just press pic. size key on the remote control and choose the picture size of your choice.
Jun 18, 2015 | Televison & Video
Want to make all my pictures reduced to smaller so as to not take up so much space & new pictures that I send in emails small.
The size of the pictures on your phone do not affect the battery life at all. Also, pictures that are already on your phone cannot have their size changed. You would need to check your camera's settings to see if you can change the size of any pictures you make take in the future.
Nov 10, 2014 | Cell Phones
How do i change my pictue size using remote control
Hello
To select the picture size using the remote control
Press "Picture Size Button" on the remote control
While the Picture Size screen is open, you can do one of
the following to select the desired picture size
Repeatedly press "Picture Size Button"
Press the corresponding Number button (0-6) while the
Press UPor DOWN button, while the Picture Size screen is open
Using these functions to change the picture size (i.e.,
changing the height/ width ratio) for any purpose other than
your private viewing may be prohibited under the Copyright
Laws of the United States and other countries, and may
subject you to civil and criminal liability
OK
May 11, 2011 | Toshiba Regza 37HL17 37 in. LCD TV
Need to change picture size
In the menu under picture size and quality, you can set it for the highest number of megapixels and finest quality.
Jul 16, 2010 | Pentax *ist DL Digital Camera
How do i adjust the picture to fit the screen?
The wide button on your remote adjusts the picture size. Each time you press it you adjust the picture. If repeatedly pressing the wide button is not changing the picture size check you cable/satellite remote control. Look for the hdzoom# button. There may also be an aspect or format button. When you adjust this the picture size changes and between the Sony remote and the cable/satellite remote you should be able to come to a happy medium. If the picture size still isn't changing you might not be set to the correct resolution i.e. 1080i on your cable/satellite box. It might be set too low or you might be in the wrong input (av 1 av 2 hdmi 1 hdmi 2) etc.
Jul 07, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I need the easy share c613 to take pictures in 680 x 460 size. Will it do it?
No. The smallest pictures the C613 will capture is 1.2 MP, not the 0.3 MP you're asking for. To change the image size, press the MENU button then use up/down to select "Picture Size."
Jun 22, 2010 | Kodak EasyShare C613 Digital Camera
Need to change to picture quality , reduce file to email format
Go into the Shooting menu and select "Quality." Set to Standard to reduce quality and file size.
Feb 04, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
I need to know how to reduce picture size as I can only tkae about 10 pictures on the camera
press on the menu button and on the settings select image size and right arrow to enter into the options of the image size and select the desired size
as you would know you can also change the image storage location in the same process that has been stated above
happy clicking
Jul 25, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
PICTURE SIZE
Menu- Setup- V. Position + (from either the front panel or remote) until more of the lower picture is visible. If the picture size is entirely too big, you'll need to change your aspect style. This model will only allow you to change the aspect style if it is not in 1080i mode. However, most newer HD converter boxes allow this feature. I would check the converter manual.
Nov 17, 2007 | Hitachi 61UWX10B 61" Rear Projection...
Emerson Lc320em1 TV Logo
26 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
