We have to keep turning of and on the reset button because it turns off automatically after a couple of minutes use or wont turn on at all or after a while playing with the reset switch. We cant turn on the way it used to be which was just press start. Sometimes it feels like it wont turn on anymore but next day it turns on again although through the reset button and off again after a two or 3 minutes use !
SOURCE: cadence DX15 motor stops after 10 minutes
Dear Sir:
The probllem is the lack of lubricating between deck vs belt deck the produce enough friction, and the machine has been designed for autoprotect the electronic system(component).
By that reason the equipment Shut down. Please RUN the software calibration for diagnose and troubleshooting see your user manual.
Otherwise see my personal TIPS. for diagnose and Trouble.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
