Question about Hotpoint Ovens
Hotpoint oven not working as cannot set time. what does fu.14 mean on the display
Cannot set the time on oven so fan oven will not work
  • 537 Answers
SOURCE: Convection/Conventional in same unit SC302ZS
f the oven doesn't heat and the on-off light works, test the appliance controls, motor,
and heating element .
Posted on Nov 15, 2007
  • 236 Answers
SOURCE: hotpoint BU62 bouble oven
sounds like the bott oven element has gone, or faulty thermostat.
Posted on Feb 16, 2008
barkencoa
  • 3463 Answers
SOURCE: HOTPOINT DOUBLE OVEN mODEL uy46 BOTTOM OVEN NOT WORKING CANNOT CL
While it is flashing auto ,you will not get the oven to heat up.
You must press the timer buttons in the correcf sequence to cancel auto.Refer to user hand book.
If you suceed with this, and the oven still does not get hot, then the element has probably failed.
Posted on Nov 23, 2008
barkencoa
  • 3463 Answers
SOURCE: fan assisted oven is not heating up
Hi.
Yes it is more than likely to be a faulty oven element, more so if the fan is workin o/k.
Please `rate my solution.
Thanks.
Posted on Jul 29, 2009
arepairman
  • 20 Answers
SOURCE: hotpoint sy36x grill element works fine but when
it seems to me that it is a fan oven and the top element won't heat up you need a new fan oven element. it is a round element that sits behind the back grill surrounding the fan...
regards
richard saupe
appliance repairman
Posted on Mar 14, 2010
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
Hotpoint oven suddenly stopped working
Sounds like a control board problem. When the display goes out that is usually a dead board.
Mar 10, 2014 | Hotpoint Ovens
Hi Our smeg oven model SNZ91MFX1 has stopped working, and the clock just says Fu 14. Any thoughts on what the fault message means?
did you find out what this meant? I have a smeg cooker which is saying the same and can't find any info about it. Many thanks.
Apr 27, 2011 | Smeg Ovens
Hotpoint BD35 oven fan not working
The air you can hear blowing will be from the exterior cooling fan, and nothing to do with the main oven.
You need to check to seeif you have got a feed to the oven fan and element, the supply comes from the oven thermostat on the control panel.
Hope this helps.
Jan 15, 2010 | Ovens
Hotpoint sy36x display works but fan and element not working, connections seem ok
You need to ascertain that the components are getting a supply to them.
You will have to remove the oven from the housing, and remove the rear cover to check for supply to fan and element.
Jan 05, 2010 | Hotpoint SY36 Style Line Stainless Steel...
My hotpoint BD31 fan oven's temperature is about 30 degrees higher than the setting on the dial. What's the possible cause of this? Could it be that the fan mechanism isn't working?
If the fan was not working, then it would not get very hot at all as then fan forces the hot air around inside the oven.
Most manufactures allow a tolerance of plus or minus 10 degrees variation in temperature from the temp setting., so setting at 200 would give you 220 with 10 % plus, or 180 with 10 % minus, so yours is outside the acceptable range.
You can compensate by setting the thermostat 30 degees lower than normal, or the more expensive option, is to have a new thermostat fitted.
In my experience, compensating for the variation in temp, is a satisfactory solution.
However, if it gets worse, then your only course of action, is to replace the stat.
Trust this answers your question.
Nov 28, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Display works but no lights on either oven and no fan
If the display is flashing, it sounds like the timer needs resetting
U need to refer to your instuctions on how to do this..
If it does it again once u have reset it, then I suspect that the oven element has blown..
Pls leave feedback.
Thanks.
Nov 28, 2008 | Hotpoint DY46 Style Line Stainless Steel...
Top oven works bottom oven fan works but bottom oven does not work and cannot get rid of auto signal
Jul 22, 2008 | Hotpoint UY46 Style Line Stainless Steel...
Function button keeps failing
only do this if you relay know what you are doing. try asking your local appliance second hand shop it will save you time and money
Nov 12, 2007 | Hotpoint SY36 Style Line Stainless Steel...
Ovens Logo
35 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
