Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Blown fuse where is it located
  • 4 Answers
There is a thermal fuse in the circuit between the dryer drive motor, and the dryer timer motor (control). It's physically located near the blower assembly. Whirlpool 33001762 Thermal Fuse AppliancePartsPros com There is a picture of it at this link. That's the only "fuse" I could find in the parts manual I have for the MLG2000AWW.
Posted on Oct 20, 2014
The window was working until I was cleaning the car with liquid. Could this be the problem?
You my have gotten the switch wet.It may have blown a fuse.Look in owners manual under (fuses) windows..Locate fuse block and fuse location and pull that fuse if its blown replace with same amp fuse AFTER your switch is dry I hope this helps
Jun 12, 2011 | Buick Rendezvous Cars & Trucks
Changed battery then radio will not work
Most likely the fuse for the radio is blown. If the radio is factory, check the interior fuse box (normally located on the lower drivers side of the dash) for any blown fuses. Normally the fuse that will blow will say something like "Radio", "Audio", "Interior", or "Cig" near them. If the radio is aftermarket, check the fuses noted above and also check for a blown fuse located on the rear of the radio (Usually next to, or on the main power harness).
Mar 22, 2011 | Car Audio & Video
My interior lights & remote just stopped working
Can be a blown fuse, Check your owner manual for the appropriate fuse that refer to what it is for such at lights, radio etc... and the location of where the fuse in located. Once you find that out, pull the fuse out to see if the fuse is blown, if it is blown replace it with the correct fuse amp. Sometimes there are couple of fuse that are reference to the same details too.
Jan 14, 2011 | 2006 Toyota 4Runner
Blinkers not blinking or lighting up
will try to help. sounds like you've blown a blinker fuse,you'll need to look for fuse box.you did'nt specify make and model,but will try to point you to its where abouts. look under dash on drivers side next to the door. if you have an owners manual for car,look there for location of fuse box and it should tell you where the fuse location is inside the fuse box.simply replace the blown fuse and check for a blown turn signal bulb also.thank you for choosing fixya.com
Nov 29, 2010 | Dodge Ram 2500 Cars & Trucks
Unit will not turn on. Believe fuse is blown. Where is fuse located?
Fuse is located either inline on your hot wire or where you plug in the harness in the back of the unit....Also check cars fuse box for possible blown fuse.
Oct 07, 2010 | JVC KD-LH810 CD Player
Both electric rear windows do not operate
Thanks for using FixYa!
If the rear power windows don't work. Its possible that you have a blown fuse for the rear side windows. Open up the fusebox usually located under the dashboard. Check the fusebox manual. Locate the fuse for the rear power windows. check if the fuse is blown. Replace the fuse. im 98% sure that its just a blown fuse.
Have a wonderful day.
- HotRatchet
Jul 29, 2009 | 1999 Toyota Land Cruiser
Blown fuse
This fuse is most likely located under the hood in the fuse box, usually located on the right fender well. It also houses relay etc. You will find the burnt fuse there for sure.
May 28, 2009 | 1999 Volkswagen Cabrio
Can't locate 1992 civic parking fuse..
the fuse box is generally located between the drivers door and the dash board just check all the fuses until you find a blown one
Mar 26, 2009 | 1992 Honda Civic
Cking fuses on 2000 vw beetle
The air conditioner fuse is located on the fuse panel on the battery. It's the first of the 3 fuses there.
Feb 10, 2009 | 2000 Volkswagen Beetle
Alg643raw gas dryer
try unplug and plug back in first let it reset and if that dont work, check thermal fuse may be blown..the fuse located in the back next to the fan in the housing. If fuse blown unit not work, if you go to www.appliancepartspros.com choose your model and it will give diagram of location termal fuse. check fuse first make sure is blown before you order it.
Mar 31, 2008 | Amana ALG643RB Gas Dryer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
124 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
