Question about Nokia Cell Phones
Not network when i search for menual network selection is shows oprators name included which SIM i insert in. but as i select same it show no covreg
    New Friend:
  • 35 Answers
As far as I know there are two possibilities to get this error message.One is poor signal of that respective network for which you just need to switch OFF and ON your mobile and the mobile will be able to receive the signal from near by tower.You may also get this error message when you are trying to insert a sim other than which the mobile is locked to.To solve this problem you need to unlock the phone from that particular network or use the same sim to which the mobile is locked to.To unlock get unlock code from http://www.onlinegsmunlock.com/supported-phones/rs5wp7/
OnlineGSMUnlock.com
Posted on Feb 13, 2014
2 Suggested Answers
SOURCE: n 72 network prablem
Could be an intermittent provider issue, not sure. You could be selecting somebody else's tower that your provider has banned.
I tend to blame phone's antenna or an amplifier (if it has such). I have had exactly same happened to me two weeks ago with AT&T - "no access" on manual mode, unstable, weak, come-and-go connection. What I did was:
1. removed battery and SIM from the phone and kept it this way for maybe four hours
2. put those back in, did NOT turn the phone on.
3. completely charged the battery, i.e. once indicator says "battery is charged" I would unplug and plug back the AC cord - it will begin another incremental re-charge, at I would keep doing it for at least another hour.
4. turned the phone on - strong connection.
You wanna try this?
Posted on Aug 07, 2008
Vodafone sim
firstly check up with other operator......i.e. airtel etc. ....if network appears with other operator sim inserted, then it is hardware problem.....to confirm this.....insert voda sim....switch on the phone ...then go to menu>settings>phone settings>network selection>and select manual.....now your phone will start searching network......and network list (so called service provider list (or SP list))will appear.....on the top it should be Vodafone........if Vodafone appears then select it....it done......if Vodafone does not appear then its hardware problem.... solution depends on phone model....pl. mention it....older phones develop this this fault when a IC called PFO/PF/PA/or Duplexer develops fault........later phones have a IC called FEM ic in place of duplexer. in latest models its network ic.....this has to be replaced......some new phones have no solution for this
May 02, 2014 | Nokia Cell Phones
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
lg-phones
Jun 03, 2011 | LG Cell Phones
My handset model is 5310 xprss music if i have open net on handset . handset show me only 7 set allow
If you are in network selection this shows the networks you may be able to roam on even though the handset is sim free the sim is still controlled by the network including what networks it will work off
Jan 14, 2011 | Nokia 5310 Cellular Phone
Blackberry Curve keep showing SOS network
It means your phone is not receiving signal from the network. First turn off your phone, remove the battery and insert in back in, then you turn on the phone. If it still does not receive signal, then you go to the phones menu, scroll to settings, then you select the network settings, after that select the manual network search, then a list will be searched out, select the network operating network of your Sim. If it still does not see the network, then it means there is an internal problem.
Hope this information helped.
Jan 10, 2011 | Cell Phones
SIR I WANT TO OPEN THE SIM LOCK OF HAIER HC-C2076 TO USE OTHER OPERATES SIM
unlock-c2076mv03c
but vahi unlock hoga jo *#0000# karne par version show kar
Selected Model...C2076
Asking Server Access Take Few Seconds...
Successed to connect server
User name...xxxxxxxxxxxxxx
Searching Phone Please Wait :
Your Phone Version:= Dec 09 200914:17:22May 06 200807:00:00SCNGZ355*
Found Inside Version = QSC6010-SCNGZ-3550®?~
Phone Is In Boot Mode.
Prepairing Phone For Opration.
Phone Ready To Unlock..
DATE CONFIRM HC2076MT03C...
SEARCHING INTERNAL VERSION...
Found...HA2076MV03C
SEARCHING LOCKS...
LOCKS DISABLED...
Haier C2076 Unlocking Finish Restarted Phone...
error 0 in comm
error 1 in comm
error 2 in comm
error 3 in comm
Total Time Take...00:00:34
Log Saved To...C:\Advance Cdma\C2076log_5_1_2010_3_08_49 PM.txt
HOPE THIS WOULD BE HELP FULL .
PLEASE DO RATE ME.
HAPPY NEW YEAR
THANK YOU
Jan 01, 2011 | Alcatel Virgin Mobile ?£30 Text Cellular...
Am trying to use 3 sim and a lebara sim in google nexus one.But its not working at all. i have no idea what's wrong with it.When ever i insert a sim card it is showing a network but not connecting or...
Firstly you need to make sure that the phone is unlocked i.e. it is not tied to another network. Secondly, perform a manual network search. You do this by going into your menu and selecting: (i)settings, (ii) network services, (iii) network selection, then (iv) manual. It will then search for available networks: click on any network first, and then go back into it again and click on Lebara. If that still does not work try the SIM in a different handset.#
Lebara Customer Service
Nov 21, 2010 | Google Nexus One Smartphone
No network covrege
Hi, It may be due to the network service provider in that area alone.You try putting ur sim card in other phones and if it shows the same , then sim card is ur prob.change to a new sim with same number from ur service provider.If the above two shows positive then the receiving antennae of ur phone is weak. service ur phone.
regards, sathyamoorthy
Nov 15, 2010 | Nokia 6230
When i put my sim card into my blackberry it says invalid sim... what is going on? It's an unlocked phone I purchased on the internet and it is not working... can anyone help me?
It looks like the telephone is SIM locked.
If you go to Options > Advanced Options > SIM Card and type MEPD.
This will bring up another screen. If the Network option shows "Disabled" then it is unlocked.
If its locked go back to the seller or buy an unlock code online.
Hope it helped.
Nov 16, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
I want oprate internet in my S22 but i have no software & pc soot so wate can i do?
I won in this matter. I have postpaid airtel connection  Call the operator for GPRS connection then in internet service section, in settings, Go to edit profile select sim There are many profile make new profile edit profile data account sim gprs (Airtel gprs) connection Type select HTTP User name password blank then again services section.>data account >gprs>select your sim gprs>edit>username.password blank Like this I got internet connection and get emails but when try to open some website it shows NOT ENOUGH MEMORY
Mar 13, 2009 | Handmark Software MobileLists (950142) for...
N 72 network prablem
You wanna try this?
Aug 05, 2008 | Nokia N70 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
