Question about Bodum Bistro Toaster
My element has burnt out
Just need a replacement element
    New Friend:
I love my Bistro toaster but it will only heat on one side,
is it repairable?
Posted on Jan 18, 2015
Original Heating element and replcement elements both burnt through at same isolator...just that lucky or another issue that causes that problem?
If the new element burnt through quickly then I would suggest replacing the insulator just to be sure before installing a new element.
Nov 05, 2015 | Dryers
The wire connecting to the heating element keeps melting/burning. Ive replaced it twice, each time it melted, how do i fix it?
What size wire? When you replaced the heating coil, what did you use? Was it OEM? What part number? Do you have an ohm meter?
Apr 11, 2014 | Dryers
I have a Jenn-Air JES9900 range and the right front burner is not working but the hot indicator light remains on. Is this just a switch that needs to be replaced?
make this test and fix it. God bless you
Surface Element Switch
If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Surface Element Board
If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element
If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element
The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element
If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Element Receptacle and Wire Kit
If a surface element won't work, there may be a problem in the element receptacle. The surface element plugs onto a terminal block type receptacle. Over time the terminals in the receptacle can have a bad connection and overheat. Look at the receptacle contacts with a flashlight. If the terminals look burnt you will need to replace the element receptacle. also make sure the element prongs are clean and not burnt. If the prongs are burnt bad the element will need to be replaced also.
Loose or Burnt Wire Connection
If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem
Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Nov 04, 2013 | Kitchen Ranges
Maytag Dryer MDE3706AYW has a burnt black wire, did the wire just have a bad day or do I need to replace the heating element and the wire?
All should be good. I think the element had run on due to a bad hi-limit thermostat that you said you replaced.
Oct 17, 2012 | Maytag MDE3706 Electric Dryer
Burners are working oven is not working ?
The heating element may be burnt out, you will need to replace this element if it does not heat up when the oven is turned on, try turning the oven to broil if the top element heat up then indeed it is the bottom element and need replacing.
Dec 18, 2009 | KitchenAid KESC300 Electric Kitchen Range
Broil Unit Element burnt out. How do I install a
you will need to unplug the range
depending on the model you should see screws on the back plate of the broiler element remove those and the clips keeping it up
now SLOWLY pull it forward, sometimes you can pull the wires off, they dont give a lot of slack
slip of the clips
put on the new one and reverse your order out
Oct 09, 2009 | Kitchen Ranges
No heat when switched on,
two things. First, You could have a dryer element burnt out. To see if the element is out you need to visually check to see that it has not been broken or you can use an electric meter to test for continuity. Make sure you disconnect all the wiring from one end of the element before testing for continuity. 2nd you could have a burnt out high limit swithch. Take the model and serial number of the unit to an appliance parts store for replacement. High limit switches nor elements are that hard to remove and replace. Make sure to unplug the unit before doing any work. Good Luck
Dave
Jul 28, 2009 | Dryers
My maytag neptune dryer is not drying/ what do I do first
to check the element you need a continuity test this test insures there aren't any breaks in the heating element that you can't see. If there is continuity then you possible could have a hi limit switch (this looks like a small round button about the size of a dime, located in the housing holding your element) burnt out. If the element is burnt out there will be no continuity on the element. If there is continuity then take the hi lmit swithch out and replace it. Take the model and serial numbers to an appliance parts store for replacement. Good Luck
Dave
Jul 21, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Bodum Bistro Toaster Logo
194 people viewed this question
Top Bodum Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Bodum Kitchen Appliances - Other Expert? Answer questions, earn points and help others
