Question about Epson Stylus Office Equipment & Supplies
Severe paper jam in my Epson stylus bx300f
All paper jam procedures have failed
IrishDruid
  • 2712 Answers
SOURCE: Paper Jam in R300 Epson
Look for any debris, bits of paper, etc in the printer. You can try using a can of compressed air to blow out any debris inside. Should that fail, try a hard reset: Unplug printer from PC and power source, wait about 5 minutes and reconnect everything and see.
The paper jam error could be due to one of the following:
  • Check for paper in the paper tray
  • Check the size of the paper in the paper tray to see if it is the same as what the printer is set for.
  • Defective D-roller
  • Debris in the paper path
  • Gears not turning or broken gear
  • Defective paper tray
  • Broken input sensor flag
  • Defective input sensor board
  • Defective system cable 2
  • Defective system board
  • Exit Sensor flag (Fuser)
  • Exit Sensor board (Fuser)
  • System cable 1
If there is no bit of paper or debris stuck in the rollers, it would indicate something more serious, and in need of servicing. If your machine is under warranty, I suggest you take it back to the shop and get it replaced.
If your warranty has run out, then you'll either have to get it serviced or buy a new printer (whichever works out cheaper for you)
Hope that helps!
Posted on Jul 04, 2008
Dipu007
  • 2110 Answers
SOURCE: Epson Stylus D88 Plus paper jam
1. Unplug the power and USB cables from the printer. I pried open my C42UX printer, careful not to break anything. I use a flat blade screwdriver to pry it apart; there are two-three tabs at the back and two at the front. Gently push them in, and then using a bit of force pry apart the cover.
2. Next I removed the two (2) waste ink pads. They are located at the back on the left hand side. I used the flat blade screwdriver to lift up the ink pads (they were soaked). Please use rubber gloves as it gets very messy.
3. Next I took the pads to the kitchen skin and washed them with just plain hot water until they were white again. I just let the hot water run on them (the pads are about three inches long).
4. Once washed I dried them using a hair drier. (you could place it the sun for a few hours or on top of your heater or maybe in a heated oven; (make sure you do not set it on fire with too much heat).
5. Once dried I placed the pads back in the ink waste bin at the back of the printer.
6. I closed the printer cover and put back all the pieces and plugged in the USB & power cable and turned it on. (Yes the lights are still flashing).
7. Go to this link and download this software: http://inkjetprinterhelp.us/epsonSSC.html
8. Install the software and run it.
9. Select your printer and model number ( It only says C42 there is no UX, choose it anyway).It will ask if you replaced with new pads; say “YES”. Then close the window.
10. Now right click on the SSC service utility, it looks like a printer icon near your clock in the task bar.
11. Then click on reset counters. You can do all other stuff with this utility too.
12. Turn off the printer power and then turn it on again. If necessary un-plug the power cord from the back of the printer, wait 20 seconds. Plug it back in.
13. THERE YOU GO! IT WORKS AGAIN.
14. By the way I use generic ink and I fill my own cartridges. I use ink from www.atlanticinkjet.com. Great stuff.
try this and let me know it worked or not ...
Posted on Dec 12, 2008
joedirty
  • 158 Answers
SOURCE: epson bx300f installation
here it is-please vote your rating
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=YZnBT5wk60aVKZQrD1EvP7U002FNsqU002FMgplS&tc=6
Posted on Nov 08, 2009
SOURCE: How do I change the a discharged cartridge in the
pree menu on the printer > go to maintenance > go to ink cartridge > press ok > open the lid > the cartridge will be in installing position, pull and relaese the lock > pull the cartridge u want to change using the clip provided. > undo the plastic pack of the new cartridge, tear open the vaccum pack, pull out the yellow tape > keep the cartrigdge on the hoder straight and gently press the top until u hear it click ! !!
Posted on Dec 10, 2009
vanherringto
  • 1738 Answers
SOURCE: i cant seem to find a scan option on my epson
Once all of the drivers are downloaded and the printer is connected to your computer, you can initiate a scan of a document two ways.
First, you can select Copy on the printer and it will copy the document placed on the scanner.
Second, you can scan a document to your computer by going to: Start > All Programs > Accessories > Paint.
When the Paint program opens, (in the upper toolbar) click: 'File' and scroll to 'From Scanner or Camera'. Then, select your device (Epson scanner) and click, 'OK'.
Continue with the prompts and your scan will be imported into the Paint Program. To save your scan, Click, File > Save As > (name your document) and select a folder for your scan to be sent to.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thanks.
Posted on Feb 03, 2010
Epson BX300F display shows priner error see documentation
Epson BX300F display shows priner error see...please help my
Dec 19, 2010 | Epson Stylus Multifunction Printer/...
There is no data with my Epson BX 300f giving paper & card limits
Try this link
http://www.epson-europe.com/content/EU/en_GB/products/business_inkjet_printer/product_spec/EU-Product-Specification-BX300F-EN.ilocal.htm
Jan 25, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Need to scan then email on an epson office bx300f but can't find instructions how to?.........
hmmm honestly the only solution i can think of is checking the manual that comes along with the package or if there is an installer, a manual is included in it for instructions... but if u dont have it there is a website for manual dwnload and tech support... hope this is helpful..
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-Office-BX300F/Drivers-Support
Sep 10, 2009 | Epson Stylus CX6600 All-In-One InkJet...
EPSON tx100 refuses to print - ink light on
ink light on? Check status monitor. Usually after jammed paper, printer trouble to recognized ink. Do change ink tank procedure, unplug and plug again ink tank.
Jun 13, 2009 | Epson Stylus Multifunction Inkjet Printer/...
EPSON BX300F prints a page and then shows Printer Error.
Try uninstalling your printer, rebooting the computer, then re-installing your printer. If this does not work, it will require the printer top cover to be removed for further investigation. Either take the printer to a technician to investigate, or if you want to have a go yourself, post a new comment to this effect and I will provide information on how to proceed.
Mar 07, 2009 | Epson Stylus C86 InkJet Printer
USER MANUAL FOR EPSON BX300F PRINTER
Guru epson expert? rotflol
Weird, I have such a model just right by my side...
Epson Stylus Office BX300F. Tks anyway, Guru epson expert
Nov 18, 2008 | Office Equipment & Supplies
18 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
