Question about Honeywell Water Heaters
Honeywell wv8840b5001 will not light.
WV8840B5001. Why doesn't the burner ignite?
Gas control is bad?
Air intake screen is dirty?
FV system is tripped.
Resources on following link:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Gene
Water Heater Timers Save Money
Jun 14, 2015 | Honeywell Water Heaters
Honeywell rth2310b 5-2 day is not working. light stays on and buttons dont work, how can i fix it?
Honeywell has a help line They have access to all of their codes and understand your problem. Google them for the phone number.
Sep 01, 2014 | Honeywell RTH2310B 5-2 Day Programmable...
Honeywell WV8840B1109 temp control valve on water heater. Status light @ 4 blinks between 3 seconds indicating "high temperature shutdown" even though lighting pilot with water cold. .
II have exactly the same problem: Honeywell WV8840B1109 temp
control valve on water heater. Pilot is on, but the burner won't
no matter how high I turn the temperature knob. Status light blink
4, which by the controller is "high temperature shutdown" and has
nothing to do with the problem. The real problem is that the
computer chip in the controller has gone bad. Problem is solved by
changing a new gas control valve/thermostat. The old Honeywell
control valve uses pure mechanical stuff and was very reliable,
almost never has a problem. I don't understand why they switch to
this new electrical one which use the tiny voltage generated by
the thermopile to run, easy to break, because of the electric
chips, and is more expensive. The only reason I can think of is
that they want to get more money from our pocket.
Nov 01, 2012 | Water Heaters
Wiring a Honeywell V8043E for two zones
Honeywell posts pdf manuals.
Google seArch Honeywell V8043E .pdf
Include .pdf in search parameter to find manual with wiring diagrams.
http://www.forwardthinking.honeywell.com/related_links/water/5000_series/install/95c_10932.pdf
Oct 26, 2012 | Honeywell V8043E1012 Zone Valve 3/4 Sweat,...
Light stays on
Question posted under Honeywell thermostat.
If you have honeywell thermostat, then model number is located on back of device.
Google that model number in following format: Honeywell xxxxx4 .pdf
That will give you on-line pdf manual that is downloadable and searchable.
Then re-post question with exact model number and include what you are operating so expert can access and read manual alongside you.
If you have some other device, then post the brand and model number, and include what voltage, and what you are controlling for best possible solution.
If you have a timer or a switch, it is possible that more information is available on following links:
http://waterheatertimer.org/How-to-wire-switches.html
http://waterheatertimer.org/How-to-wire-timers.html
Aug 27, 2012 | Honeywell T6360b1028 Room Thermostat
I have an A. O. Smith Model FPSH 40-261 hot water heater. It won't heat water. there is a green light on the control flashing. What does it mean?
AO Smith uses the Honeywell ICON gas valve with green indicator light.
Some models use White Rodgers Intellivent with a row of indicator lights.
The gas control blinks the error code:
Open following links to identify gas control thermostat and read possible error codes:
http://waterheatertimer.org/pdf/Honeywell-Gas-Valve-LED-Codes-2000.pdf
http://waterheatertimer.org/BW.html#Temp
http://waterheatertimer.org/How-to-adjust-water-heater-temperature.html#intelli
Jul 18, 2011 | Water Heaters
How to program my honeywell thermostats? program my heating in honeywell
pick the right model from this list http://yourhome.honeywell.com/home/Products/Thermostats/ click on detail and it will offer you downloadable manual.
Apr 09, 2010 | Honeywell Water Heaters
Water Heaters Logo
238 people viewed this question
Top Honeywell Water Heaters Experts
paulcarew
Lawrence Oravetz
Steve
Are you a Honeywell Water Heater Expert? Answer questions, earn points and help others
