Question about Raymarine C80 GPS Receiver
No signal from gps ant - Raymarine C80 GPS Receiver
Garmin 310xt software
Run the Garmin WebUpdater to load or reload the latest software to the device.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
May 15, 2012 | Garmin Forerunner 310 Xt Gps Sport Watch...
Garmin 660 opens to where to/view map/travel kit/after that touch screen does nothing.good battery an ant signal.thanks
This is a well know issue with this unit and caused by a touchscreen failure. Please see this link for more info. Too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
May 27, 2011 | Garmin Nuvi 660 GPS Receiver
I have no satellite signal??????
Most likely you have a bad GPS+Ant board in your T1500.
Jan 12, 2011 | Magellan Triton 1500 GPS Receiver
Won't recieve satellite signals
This message is caused by a bad GPS + ANT circuit. Please visit http://www.jungleghost.com/repair_service.shtml as they do this kind of work.
Nov 22, 2010 | Magellan Triton 500 Handheld GPS Receiver
MAGELLAN TRITON 400 RECEIVES NO SAT SIGNAL
Sorry but you most likely have bad components in the GPS + ANT on the motherboard.
If the unit is in warranty .. return it to Magellan
Oct 03, 2010 | Magellan Triton 400 Handheld GPS Receiver
DOES NOT PICK UP THE SATELITTE SIGNAL
Sorry but you most likely have a major component failure in the GPS + ANT on the motherboard. If the unit is under warranty send to Magellan.
Triton 1500 GPS, I can't get any green bars to receive position.
You may have a few problems. First the GPS signal is controlled by a special GPS+ANT card in the 1500 and it may be defective. As for dates, etc. this could be caused by an other firmware update or a bad software file. Go to the Jungle Ghost Repair Center at www.jungleghost.com they have parts for the Triton units.
Dec 29, 2008 | Magellan Triton 1500 GPS Receiver
Cant install Garmin Connect software
reboot the computer in safe mode. (HIT F8 during the startup) then after the computer loads put the ANT stick in the USB slot and it will then be recognized.
remove it and then reboot normally. Now simply reinsert the ANT stick after starting the ANT agent.
worked like a charm
enjoy
Dec 03, 2008 | Garmin Forerunner 405 Handheld GPS...
No Signal
I connected the cable to Ant-A, then connected a short cable from the out loop to Ant-B. Works fine. Didn't have a manual, had no idea.
Sep 05, 2008 | Mitsubishi WS-55807 TV
Raymarine C80 GPS Receiver Logo
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
