Question about Canon Cameras
580EX flash popped twice and sparked gets hot even turned off defaults to TLL i use always in manual screen comes on but lite up opned up flash and saw black soot on a card behind where the bulb is bulb is ok.
    Master:
  • Canon Master
  • 442 Answers
Stop using the flash immediately and don't open it. The capacitor in camera flash can store enough energy to kill you if you make contact with it!
You have a defective flash and it needs to go into Canon for repair. There's not anything you can do to repair it yourself.
Posted on Nov 26, 2014
SOURCE: speed of camera always maxes at 250 by default when external flash is put on.
Thanks for offering the help.
I fixed it by just sitting down and going through every setting through trial and error.
A huge pain in the rear end. I got lucky and figured it out.
Thanks,
Posted on Feb 10, 2008
SOURCE: Broken Hot Shoe
This link gives step-by-step instructions with pictures for replacing the shoe.
http://planetneil.com/tangents/2007/05/31/repairing-the-canon-580ex-hotshoe-foot/
Posted on Jul 19, 2008
SOURCE: Canon 580ex "pops" in a baad way
It is very dangerous though... [referring to Alexander's solution]... I've been shocked more times than I care to really admit, and that cap can cause some serious damage. Be careful!
Lance.
Posted on Aug 07, 2008
SOURCE: Canon speed lite 580ex 11
I just got the 580 and had trouble with it blinking all the time, the bounce card was out about a mm and I did not realize it, once that was pushed all the way back--voila.
Posted on Apr 24, 2009
SOURCE: Broken flash Canon 580 EX.
Most likely that Capacitor has "Gassed" as we say. It is now destroyed, however usually too the Driver Semiconductors "Blow" as well. I have seen this before, it is not uncommon. An enormous amount of energy is stored in this capacitor and circuit, and they often fail in an explosive manner.
What you need to do, is find a Canon authorised servicing center, contact your local or head office of Canon, and inquire as to a local repair center.
Now when you take the Flash in for repair, please ask for a 'Quote" before allowing any repair work to commence, this then will allow you to make an informed decision as to repair or replace.
It is hard to give an exact cost but I would expect, that around $80.00 to $125.00 for the basic repair, would be about right for a repair. BUT depending on what exactly was wrong, it could very quickly escalate.
I think you may find, that the cost of repair, may even approach, the cost of a new unit? This is also why getting a "Quote" is beneficial.
However if you can desolder and solder, could obtain the EXACT Rating and Value Capacitor and Semiconductors, (read ALL damaged bits) and were prepared to do a little work, it is entirely possible to repair this unit oneself. but be very careful when doing so, as flash guns can give a very very nasty "Bite" (speaking from experience :) lol)
Posted on Oct 03, 2010
How to restore factory settings for canon 430exii
The manuals for the 580EX and the 430EX say the following under "Reverting to nnnEX Default Settings": "When nnnEX is attached to an EOS camera equipped with a button, you can press it to revert the xxxEX's settings (except custom settings) to the default.
May 05, 2014 | Canon SPEEDLITE 580EX TTL Flash
580 ex repair
If resetting the camera to factory default settings WHILE the flash is mounted on the hot shoe and turned on doesn't help, you may have physical damage/failure with the flash and it will need to go in for repair. This sounds likely if you've had an ongoing problem since you got the flash.
You could also try checking the ETTL sensor to make sure it's not damaged or blocked by lint, check the flash on another camera to see if the problem persists, and check the hot shot mount on the camera and the flash to make sure they're not damaged and solid.
May 18, 2013 | Canon SPEEDLITE 580EX TTL Flash
My canon 580 EX II stops firing even with new batteries
You must disable the 580EX II form using the 4AA.
4AA must be needed when using hv power pack.
Just let the 4AA use & display the LCD panel.
More help, repairs & troubleshooting send me an email.
atdlee@netzero,com
Oct 21, 2012 | Canon Speedlite 580EX II TTL Flash
I just purchased a Rebel T2i and a 580EX II Speedlight. After approximately 50 flash photos, the speedlight shifts slightly to the rear and it appears the contact between the speedlight and camera...
It would appear to me that the flash was not locked in position and has move back on its mount which would cause the flash to go into complete manual mode or loose complete communications between camera and flash.
I would suggest shutting the camera and flash off remove the flash first unlock the little locking leaver on the bottom. The 580EX and the 580EX II differ in that the 580EX II has a leaver rather then the huge locking screw. Once apart reinsert the flash unit back into the camera hot shoe making sure that the forward edge of the flash mount is seated as deep into the Hot Shoe as possible and lock it into position. It should click into lock position. Biggest thing I have with my "crew" is when there is a flash installed on the camera they pick the camera/flash unit up by the flash that's a real bad thing cause the flash mount is light plastic and it'll ether break, twist or even unlock the flash enough that the camera falls off of the flash. Pick the assembly up with both hands lens and body. I'm not saying you are doing this but when my crew/working associate's do this I'm not happy.
Although that new switch idea is great it also can be unlocked without noticing.
Diagram
Jan 06, 2011 | Canon Speedlite 580EX II TTL Flash
580ex off camera shuts down after a minute or so of standby
No and no, the flash is by default programed to shut off after 1 minute .If you were using the flash on-camera, the flash would automatically power itself on when camera activity is detected but when the flash is detached, it doesn't wake back up.
To change this you have to turn off the auto shut off in the flash menu:
1. Power the flash on
2. Hold down the back light /C.Fn button until "Fn 00 0" appears on the screen
3. Rotate the selector wheel until you see "Fn 01 0"
4. Press your selector button down so that the 0 begins flashing
5. Rotate your selector wheel to change the 0 to a 1
6. Rotate the selector to the "Fn 14 0" position and set it to 1
7. Press your selector button to save this parameter
8. Press your Mode button to return to the main screen
Now your flash stays on as long as the flash switch is turned on ON, and as long as you have juice in the batteries.
Do not forget to turn off the flash after you are done.You can reverse it anytime, but you have to read the manual for that..
Same setup can be found in the manual
May 07, 2010 | Canon SPEEDLITE 580EX TTL Flash
Wrong owner's manual here for Canon Speedlite 580EX Flash
You can get the proper manual from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=316&modelid=14998
Dec 27, 2009 | Canon SPEEDLITE 580EX TTL Flash
My Rebel T1i's built in flash stopped working after I used a 580EX external flash on it. It won't even show up on the LCD screen.
Really? the best solution available is to take the top of your camera off?
i don't think so.
Here's a very simple solution I found to get the flash to pop up without destroying your camera.
http://forums.dpreview.com/forums/read.asp?forum=1031&message=31993875
the person suggests using a fingernail. (s)he must have long fingernails. I had to use a piece of paper folded in half. Swipe the paper from back to front, as in, from the eyepiece side towards the lens side.
Here's a picture: http://www.flickr.com/photos/dougpardee/133066175/
good luck
Sep 25, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Switch from film to digital cameras.
I also own a Vivitar 285 that i used with my Canon F1 manual 35mm camera. Most older cameras before the advent of digital, had a hot shoe on top of the camera, or like in my case, the hot shoe went over the rewind knob. I also had to plug in a power cord from the 285 flash foot and the cameras PC connection in order for the flash to work on some other cameras. The Canon Rebel XTi has a TTL (through the lens) hot shoe usable with Canon's own EX flash units. You can buy a "hot shoe to PC connector" if the TTL camera hot shoe doesn't work, but be extremely careful, the only problem that exists with the older manual flash units was the trigger voltage is as high as 200+volts which would fry digital camera hot shoes. I tried my unit with a Wein flash trigger device on the PC cord of the flash and my Canon D60 with it's own flash. All shots were overexposed and washed out highlights.  Here's a copy of the hot-shoe review:h The EOS 400D's hot-shoe can be used with Canon and third party flashes (although sync only on most third party units). The hot-shoe is E-TTL II compatible. Compatible flashes include Speedlite 220EX, 380EX, 420EX, 430EX, 550EX, 580EX, Macro-Ring Lite, MR-14EX, Macro Twin Lite MT-24EX and Speedlite Transmitter ST-E2.  The Canon Rebel XTi doesn't have a PC socket to plug in a manual flash trigger cord which common sense tells me there is no provision to step up the voltage to trigger manual flashes - so my answer is this combination is not a good idea on a Canon Rebel XTi. Hope this helps.
Dec 12, 2008 | Vivitar 283 Flash
Broken Hot Shoe
Jun 16, 2008 | Canon SPEEDLITE 580EX TTL Flash
Buy the flash tube and the cap., if they are bad.
It is not that hard, I can help.
Alexander
atdlee@netzero.com
Sep 04, 2007 | Canon SPEEDLITE 580EX TTL Flash
Cameras Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
